Some oil filter questions
mrchristian
#11 Unread post by mrchristian »
slimcolo wrote:1000 miles seems about right for the first oil change. I would then change it at 2000 more miles (3000 on odometer) After this I would go to the recommended intervals. Even though manual says to change filter every other time I still do every time.
For air filter cleaning (foam type) use Dawn regular scent non-ultra. (this is what UNI filters recommend) I prefer to then use K&N filter oil because it is red and you can really tell if you have whole filter covered. (one small can should do filter at least 10 times) A lot easier and less messy than old Harley foam filters that used motor oil!
Good call on the Dawn. I'll switch to that as soon as I finish off the No-toil degreaser which works okay but is too expensive. You cut the Dawn considerably with water and let dry I assume?
Yeah, no threads to tighten with my oil filter. It sort of hangs on the outlet and is held in place with a spring on the oil cover so its really easy to change. The oil filter itself is on the outside of the engine case (with big words indicating OIL FILTER :lol: ) and its so easy to change the oil, I would feel stupid if I didn't have my friend teach me how to change it. The local dirt bike place wanted $60 bucks or something crazy to change it. That was way cheaper than the dealer, too.
My local CycleGear stocks some 10W40 oil for $4.50 a bottle:
http://www.cyclegear.com/spgm.cfm?L1=50 ... AS_12365_G
Good stuff and cheaper than Autozone.
