is there an electrician around?
bei
Real Name: Bei
My Motorcycle: 2004/Suzuki/Gixxer 1000
Re: is there an electrician around?
#11 Post by bei »
some more pics
bei
Real Name: Bei
#12 Post by bei »
If you pay more attention to the front wheel, you can see a black tied down to the wheel to create a tension to hold the front end of the bike low. But the speedo stays at 0mph no matter how fast i go and also the milage won't add up as well.. weird
bei
Real Name: Bei
#13 Post by bei »
Buzz
You recommended to refer to the service manual for checking the speedo and odo meter, I have downloaded a version online, do you happen to know that if there is voltage flow to the meter which shows on the panel cluster cuz it stays at "0MPH" and able to see the total milage and trip a and trip b mileage, so that means that there is power going to the sensor, so do you think that there might be some thing else to it? because the "0MPH and the odo does not add up while the bike is ridden.
bei
Real Name: Bei
#14 Post by bei »
man, tomorrow my appointment with the dealer is gonna cost me an arm & leg, just for a diagnostic to find out why the meters don't work, and who knows what other damages will show up on this bike. crossing my fingers
#15 Post by BuzZz »
If the speedo has power (as yours obviously does) and does not register actual speed, it points to a problem with the speedo sensor. Either a bad connection or a toasted sensor. The gauge cluster is not seeing a signal from the sensor, for some reason.
