honda rebel idling problems
fireguzzi
Real Name: Trevor
Re: honda rebel idling problems
#11 Unread post by fireguzzi »
+1 what jstarkywarky said. It probably needs a cleaning but it only takes a second to play with the idle speed adjuster.
jstark47
#12 Unread post by jstark47 »
fireguzzi wrote:+1 what jstarkywarky said.
"starkywarky" ???? I've been called a lot of things before, but never "starkywarky"!!! :laughing: :LOL2:
fireguzzi
Real Name: Trevor
#13 Unread post by fireguzzi »
Yeah, don't ask cause I don't know. My mind thinks and my fingers follow. :laughing:
bobo333
#14 Unread post by bobo333 »
jstark47 wrote: Just a random thought, but do you have your idle speed setting turned way down? (I agree, you probably have a dirty pilot jet on the carb, but it only takes a sec to check the idle speed setting.)
Do I need a special gauge or something to check the idle speed? The rebel doesn't have a tach so I'm unsure how to check it without additional instruments.
JC Viper
Real Name: JC
#15 Unread post by JC Viper »
Get the bike warmed up, adjust the idle speed knob and turn off the choke and see if she sputters and dies. Before the engine dies give it some gas to keep her going and play with the knob increasing the idle and see if that does the trick. A tach isn't really needed for this if you are familiar with how the bike feels in a normal idle.
Also, running a can of SeaFoam can help clean out the jets, valves and other engine parts pretty well. Just pour it into the gas tank and let it run through the system. If that doesn't work then you would need to take the carbs apart and soak the jets/ passages in some kind of cleaner (SeaFoam works in this aspect too).*
*my problems with the GPz 750 should be expunged from the record... at least this method worked on my Vulcan 500
Gummiente
Years Riding: 38
My Motorcycle: 03 Super Glide
#16 Unread post by Gummiente »
Aaaaannnnd... topic split in 3....2....1.... http://totalmotorcycle.com/BBS/viewtopi ... =2&t=38541
:canada: Mike :gummiente:
It isn't WHAT you ride,
It's THAT you ride
