edit: not "gas line" anymore, !!!!start!!!!
kar_the_terrible
#11 Unread post by kar_the_terrible »
rapidblue: if you have the time, yes new wiring will help. Keep a camera handy so that you can take pix of the ahrness as you're dismantling it.
If I may say so, that is a beautiful bike you have there :)
'78 Yamaha XS400
'86 Yamaha Radian
rapidblue
#12 Unread post by rapidblue »
kar_the_terrible wrote:rapidblue: if you have the time, yes new wiring will help. Keep a camera handy so that you can take pix of the ahrness as you're dismantling it.
yes, you may say so.
as the weekend nears my mind is becoming more set on rewiring the bike. Unless the problem is osmething simple like a loose connector, it's probably going to happen
80 honda CB750F Super Sport
TechTMW
#13 Unread post by TechTMW »
Rewiring isn't too terribly difficult, but it is time consuming.
Plus you (or the next owner) will be SOL if you need to use a wiring diagram. (the colors will be different)
If you have continuity on all of your wires, I see no need to rewire the bike.
Simply take some emry paper (very fine) and clean up the corrosion on all the terminal connectors. Then, use some dielectric grease in the plug fittings to prevent future corrosion
rapidblue
#14 Unread post by rapidblue »
so i took a look at the wiring,
the previous owner put in a battery with reversed poles, the wire that was connected to the neg terminal is red and has a fuse and the wire connected to the pos terminal is also red with 6in of balck wire on the end. That got me wondering about the rest of the wiring.
The battery does need to be hooked up pos-fuse wire & neg to ground right? because for some reason the lights still worked as is, and it started before...hmmm..
cruisinflatout
#15 Unread post by cruisinflatout »
rapidblue wrote:so i took a look at the wiring,
That IS weird....I'd take a serious look at ALL the wiring while you're in "down time" anyhow. Make sure everything is cool...it'll save you much hassle in the future. Wiring is weird...it may be screwed up and not give you any inclination until one day...bam...no start or no this or no that.
Take the extra hours now...you'll be glad ya did in the future!!
cruise flat out - www.cruiseflatout.com
With the re-emergence of naked bikes, one day soon, real men will be able to bring their motors out of the false shadows of molded plastic and show their motors to the world without fear of ridicule or shame.
TechTMW
#16 Unread post by TechTMW »
Some older bikes have a positive ground system ... do you have a factory manual or something for the bike?
rapidblue
#17 Unread post by rapidblue »
well all I have is this
and the fact that the battery that is listed for the bike has the positive terminal on the side of the red/fuse wire and the battery that is in there has the neg terminal on the red/fuse wire.
I just assumed it was a neg ground from this and te recommended battery
rapidblue
#18 Unread post by rapidblue »
ok this bike is starting aggravate me.
took the bike apart tonight. checked all the wires, they are all good, all the connections are snug and as they should be.
one thing i did notice was that on the generation("ignition dymano" in the above picture, one of the points sets was not in contact with the center spindle...is this a problem?
also could the regulator be an issue? would a regulator from a newer bike be useable in my bike?
rapidblue
#19 Unread post by rapidblue »
well still nothing
checked the coils and plugs there is spark
both cylinders have compression and there is gas in the tank and when I took the carb off they were all clean inside and the throttle valves were openigna dn closing freely
im so lost and getting aggrevated
any ideas?
cruisinflatout
#20 Unread post by cruisinflatout »
I feel for ya...I had a heck of a time getting my current bike to run...
If you have spark (and I assume there is no way the coil wires got reversed between the cylinders) then maybe it is a fuel issue after all. I've had petcocks crap out on me before.
I would prime the carbs and see if that helps...
all ya need is fuel, spark at the right time, and compression...somethings missing...hope you find it soon!! :righton:
