New Bike - 2004 R1150RT
Grey Thumper
Real Name: Dino
Re: New Bike
#11 Unread post by Grey Thumper »
jaskc78 wrote:The tech also mentioned that it's running a little rough and sounds like it needs a valve service, so hopefully my Clymer arrives soon so I can start practicing that 6k valve adjustment.
An '04 bike that's run less than 6k? That's pretty amazing.
sapaul
Re: New Bike
#12 Unread post by sapaul »
I am glad the wiring turned out as it has, not too bad. You will not regret buying this bike although it sounds like the previous did not keep to the service schedules. I had the 2002 model and it never missed a beat and was a really really good bike to do long trips on. Hardly any wind gets to you and the bike can outperform most riders. The boxer motor is strong and responsive but does need those services as they are only every 10 000 kms
HYPERR
Re: New Bike
#13 Unread post by HYPERR »
jaskc78 wrote:The tech also mentioned that it's running a little rough and sounds like it needs a valve service, so hopefully my Clymer arrives soon so I can start practicing that 6k valve adjustment. Will let you all know how it goes with racking up the miles.
The good news is, the valve adjustment is very easy to do on this bike. :)
It probably could also use a throttlebody sync if it is running a little rough. I have a twinmax and it makes this job a breeze.
jaskc78
My Motorcycle: N/A
Re: New Bike
#14 Unread post by jaskc78 »
Yeah, I remember you mentioning that the valves are a cake walk on this bike when I was considering the R1200R and asked your advice on periodic maintenance. I'll probably be hitting you up for some tips when my Clymer arrives, I'm going to go over it before our ride to Vegas the weekend of the 22d.
