Mintbread wrote:Bigger bangs.
To put it bluntly, yes heheh Think about it, if you have a 1000cc inline 4, each cylinder displaces 250cc. In A 1000cc twin, each cyl displaces 500cc. The torque is not a matter of pumping faster, it's more a matter of How much force the piston has when it moves down in the cylinder. If you compress 250cc worht of air and fuel and ignite it, the piston will push down with less force than a piston being driven by 500cc of compressed air and fuel.
The biggest factors when determining how FAST an engine will rev are Bora nd Stroke. Bore is how wide the piston is, Stroke is how far the piston travels from Top Dead Center to Bottom dead center.
A bike with more bore than stroke (it's wider than the distance it travels up and down) is called OVERSQUARE. Typical Race Replica bikes, like a GSX-R have Oversquare engines. This allows for High revving capabilities, as the piston has a short distance to travel.
A bike with more Stroke than Bore is called UNDERSQUARE. Harley is a good example of an Undersquare engine. (So are diesels) The piston has a long way to travel, so it can't rev as fast.
Keep in mind these are BASIC principles. Many other factors apply, such as the length of intake runners, piston shapes, valvetrain characteristics, etc. With modern technology it is easier to overcome the deficiencies inherent in each design, although generally the above remains true.
The whole 2 vs 4 thing is really a moot point anyway, unless you are planning on being a racer. Mint on his Bandit may very well be able to dust someone on a Ducati 999 in "spirited street riding" The bandit's engine is an Oversquare engine that has had some of its characteristics tweaked to be able to pump out more torque in the low and middle ranges (Compared to a GSX-R 1000 for example.)
I will agree that European bikes are over priced compared to Japanese. Blame it on economics or whatever. They are just for a different breed of biker (as are Harleys.)
