Cleaning carbs...
flynrider
#11 Unread post by flynrider »
Seafoam works pretty well if you have a minor builup of gunk in the carbs. It's not a substitute for pulling and cleaning them, though. If the small passages in the carb are already severly clogged, Seafoam is not going to fix it.
Bikin' John
'93 Honda CB750 Nighthawk
Skier
#12 Unread post by Skier »
flynrider wrote:Seafoam works pretty well if you have a minor builup of gunk in the carbs. It's not a substitute for pulling and cleaning them, though. If the small passages in the carb are already severly clogged, Seafoam is not going to fix it.
This is 100% correct. Seafoam and its ilk can be very useful in keeping your carbs clean, but it is no substitute for taking those carbs apart and throwing them in a chemical dip!
