Coolant inside cylinders
- Quick 350
- Veteran
I think the grime he sees in the cylinder is carbon build up on top of the pistons this is common for high mileage bikes and should burn off with new plugs. The big thing with coolant is it abrasive and can over a period of time scratch and oblong or cylinders. as for just cranking it a few times with plugs out no damage should have been done. Good luck!
- BuzZz
- Real Name: Never Used Here
- Years Riding: 47
Yep, I think it's just normal build-up too. The WD will help lube things until the oil takes over again. It will smoke like a french hooker for a minute or so when it first fires, but if anything, some of the build-up will be cleaned out by this experiance and things will be just dandy.
No Witnesses....
- TechTMW
- Years Riding: 10
Alot of bikes (like Ducatis) have no head gaskets.
... but an ex500 'should' have one. Are you sure it's not stuck to one of the mating surfaces? A bike designed to have a head gasket probably wouldn't run very well at all w/o one ...
