How fast have you gone?
- VermilionX
- Years Riding: 6
- My Motorcycle: '06 Suzuki GSX-R 750
so speedometers on bikes aren't 100% accurate and will display higher speed than what you're actually doing?gsJack wrote:Hit 110 mph indicated on a GS500 with a Plexi 2 fairing and 240# me onboard, that's probably about 10% higher than the actual mph would be.
if you just do it once, red-lining won't damage the engine?Joe Mc wrote:My litttle 400 tops out at 105mph, redlined in 5th. She's a wee bit scary at that speed. Only did it for a few seconds on open highway to see how fast it'd go and will not do it again!
The Mighty Mighty M50 can go fast
I've had it to 85 and that's it. Actually it felt pretty stable at that speed, not much different than 75. Supposedly the Suzuki M50 can get up to about 105, but some say that a typical maximum speed is about 95.
- Real Name: James
- My Motorcycle: 2015 Yamaha VX950(bolt)
VermilionX wrote:so speedometers on bikes aren't 100% accurate and will display higher speed than what you're actually doing?gsJack wrote:Hit 110 mph indicated on a GS500 with a Plexi 2 fairing and 240# me onboard, that's probably about 10% higher than the actual mph would be.
it will damage the engine in such a slight way its barely undamaged. Red-lining is never good no matter how short a time or how infrequently you hit it
JWF
ATGATT
ATGATT
Sev wrote:What's a bike?
JWFJWF505 wrote:its like a goat, but with two wheels.
No I didn't damage the engine.VermilionX wrote:so speedometers on bikes aren't 100% accurate and will display higher speed than what you're actually doing?gsJack wrote:Hit 110 mph indicated on a GS500 with a Plexi 2 fairing and 240# me onboard, that's probably about 10% higher than the actual mph would be.
When I said redline, I didn't mean I brought it into the red. That is not good. I just brought it up to the redline, which is 10,000 rpm on my bike.
You don't want to cruise along with the rpm's that high, but for a short time it's no problem.
My bike builds power right up to the redline, so I often shift from 2nd to 3rd, and 3rd to 4th at the redline.
'78 CB400T2 Hawk
- gsJack
- Legendary 500
- Years Riding: 30
- My Motorcycle: 02 GS500
Speedos are all off on bikes. Some worse than others. 10% high is probably a good average figure. Road tests frequently measure this and record. For example from MCN tests:VermilionX wrote:so speedometers on bikes aren't 100% accurate and will display higher speed than what you're actually doing?gsJack wrote:Hit 110 mph indicated on a GS500 with a Plexi 2 fairing and 240# me onboard, that's probably about 10% higher than the actual mph would be.
Speed @ 65 mph indicated:
04 GS500 58.5
04 EX500 59.8
02 GSXR1000 60.3
Also from MCN 02 GSXR!000- measured top speed 173.2 mph, better not redline your Gixxer yet.
Occasional and brief redlinning should not do harm to engine but it's not a good idea or neccesary. For example my GS500 hits max HP at 8500 and max torque at 7000 while the redline is 11k. I can run fastest in the twisties by keeping it cooking between 7-9k rpm, upshifting at 9k just past HP peak and dropping to max torque at 7k in next gear.
407,211 miles in 30.1 years for 13,528 miles/year average. Started 7/21/84, updated 8/26/14
- Dirtytoes
- Site Supporter - Bronze
dasda
my ninja only goes up to around 140 mph though i've on taken it to 120.BudmanTom wrote:I hit 150mph on my 88 Ninja 750 back in the day.
I've only gone 110-120mph on my V-Max.
Tom
You only live once, abuse it!
and Live Life For Today As Tomorrow May Never Come --BadAss
[img]http://www.MegaShare.com/images/images/553227170/humor00180.gif[/img]
Bikes:
2005 Ninja 500 (sold)
2001 CBR 600 F4i (current stunt/commuter)
Bikes:
- flynrider
- Years Riding: 30
'93 CB750 - 128mph by the GPS / 135 mph on the speedo. To get that I had to have the windshield off and was lying on the tank.
Back in the olden days I got a Kaw 750 turbo up to 130 mph on a long straightaway at the track. Thank God they put good brakes on those things.
Bikin' John
'93 Honda CB750 Nighthawk
