Who is your teacher?beginner wrote:Youtube is not a teacher, it is a place to watch the riding of others.MrShake wrote:Youtube offers you no feedback, thats the reason its not a valid teacher
Not Truebeginner wrote:If you shift upper body weight to the right the bike will lean to the left.If I am riding down the road on the way to work and I "Lean" to the right, this shifting my weight. My bike will lean to the right.
Why would you have counter balanced before your couter steered?beginner wrote:Pushing foward on the right grip leans the bike to the right (actually 'rolls' the bike would be more correct) and counter act the earlier counter balance that leaned the bike to the left.I add to that a counter steer of pushing on the right handlebar to aid in that lean.
Incorrect, Counter Balancing does not lean a bike. Counter Balancing controls the amount of lean, it does not initiate the lean or turnbeginner wrote:Isn't that what I've beens saying all along? Counter balancing leans the bike. It does not, by itself, turn the bike. The same is true for counter steering.It (counter balancing) is NOT a method of initiating a turn, but a control of lean maneuver.
Correct, you seem to have a hard time understandingbeginner wrote:Understanding is what's hard.Your trying to apply advanced techniques to simple, every day events.
Incorrect - Wrong - What other words can I use to express that you are not right?beginner wrote:Everybody who turns a motorcyle experiences rear tire slip. Not everybody is aware of it.You like to believe your experiencing rear tire slip at slow speeds.
Noticeable at sub 30mph... again wrongbeginner wrote:Different tires have more or less rolling resistance. Lower rolling resistance can make a difference in the amount of torque available for acceleration.You like to believe a tire change is going to give you more torque.
You do not lean your bike by counter balancing, thats now how a bike leans. The deffinition of Counter Balance is to offset the balance point you currently have. So, you would have to lean the bike and THEN counter balance. This is nessicary at low speeds or in tight turns, but you counter balance to ofset the lean you do by countersteering. You are very confused on this point and if a true beginning rider were to take what you say as truth, they would be in a world of trouble!beginner wrote:You would need to define "advanced" counterbalancing. Sometimes I lean the bike by counter steering but mosty by counter balancing. Other people may lean the bike mostly by counter steering.You like to believe that advanced counterbalancing is necessary for a simple turn.
STOP PUTTING WORDS INTO MY MOUTH. Its not only rude, but it is tantamount to lying!beginner wrote:I managed at least 150 hours of PLP last season. It was worth all the time spent. I don't agree with advising people they shouldn't practice because they might do it wrong. If you are going to say that you should say people should not ride at all because they might do it wrong.But practice when done incorrectly is only going to get you hurt or worse when you get into a bad situation and react badly due to bad foundational technique.
I don't particularly care if you agree with advising people not to practice incorrectly. The truth stands that if you ingrain the wrong behaviors in practice, then you will use the wrong behaviors in a real-life situation. Hence, practicing the wrong thing is a safety issue.
I never said people should not ride because they might do it wrong. The reverse is true.. I tell people they should ride after getting basic instruction so that they practice correctly.
Honestly beginner, I think you just need to go away before you get someone hurt with your bad advice!
