Someone please explain counter-steering to me
The Grinch
#21 Unread post by The Grinch »
Below whatever the speed is you're basically a pedal bike, where you look it where you go.
Above that speed you have enough momentum/acceleration to keep you going in a straight line. So in order to turn you must tip the bike.
Pedal bikes countersteer in the same way that motorcycles do. In fact, any single trail vehicle countersteers.
#22 Unread post by Sev »
Unless you're pushing it, a pedal bike doesn't hit usually 30mph. Added to that the fact that pedal bikes tires aren't really all that curved and on and on. I've always just turned my wheel the direction I wanted to go on my pedal bike.
So yes at low speeds a motorcycle turns the same way a pedal bike does.
And at high speeds on a pedal bike turning is more a function of shifting your weight then the handlebars. Hangin 150lbs of person off one side of a 1100lb goldwing won't do much, but hang that same guy off the side of a 20lb pedal bike and you'll turn hard n fast.
#23 Unread post by Sev »
yoda731 wrote:Per Sevulturus, the tire flattens out at the contact point. At slow speeds where the lean of the bike is negligible, tire behaves more or less like the doughnut-shaped object it is, and the flattened contact patch is essentially perpendicular to the frame of the bike.
Per me?
per Audio pronunciation of "per" ( P ) Pronunciation Key (pûr)
prep.
1. For, or by each; for every: Gasoline once cost 40 cents per gallon.
2. According to; by: Changes were made to the manuscript per the author's instructions.
3. By means of; through.
adv. Informal
1. For each one; apiece: sold the cookies for one dollar per.
2. Per hour: was driving at 60 miles per.
Posthumane wrote: Basically, the more lean you have, the less front tire turn it takes to make the bike turn, but if the front tire stays straight ahead (along the centreline of the bike), the bike will not turn no matter how much you lean. This can be demostrated with an example as well. Hop on a bicycle, and get up to speed. Then, stand up on the pedals, and lean the bike, while keeping your weight vertically above the contact patch (so only lean the bike, but not yourself). You will find that you can continue to ride straight by holding the bars completely forward. This demonstration also proves that the tire profile causes an insignificant force.
If this doesn't make sense to you, let me know. I'll try to draw a diagram and post it.
Jacob
I really liked this explanation so I stole it.
The contact patch of the tire has nothing to do with the ability to turn. It's about a weight shift and acceleration in more then one direction at a time.
pseudopod
#24 Unread post by pseudopod »
Well this has been replied to and explained to death, but I figure adding my version can't hurt. This is the most intuitive way I have found to explain it to people and understand it myself.
You are riding on your motorcycle at a fast speed. You know Newton's law: an object in motion will remain in motion. Your body and motorcycle want to continue in a straight line, not turn.
Now suddenly you jerk your handlebars hard to the right (clockwise). What's going to happen? The motorcycle tires will turn to the right but the rest of the motorcycle will want to continue in a straight line, slamming your left side into the ground.
So now instead of jerking the handlebars to the right you smoothly apply a little pressure. Instead of slamming the left side of your body into the ground it will just lean a little to the left (while the motorcycle turns right). Now you can't just keep turning right at this point or you will keep leaning over left more and more until you hit the ground anyway.
So what you do, now that you've got the bike leaning left and turning right is you turn the handlebars to the left now. If you do this super hard and fast you will, of course, slam down on your right side. But if you do this slowly and smoothly you will be able to balance the left lean you already have with how the bike now wants to lean right.
This is all intuitive and you don't realize you're doing it.
It doesn't apply as much at slow speeds because your momentum is much lower (you bike doesn't want to go in that straight line quite as much).
The Grinch
#25 Unread post by The Grinch »
It doesn't take anywhere near 30 MPH to countersteer a bicycle. I can do it at speeds as low as 10 MPH and did it today many times just to see where the threshold really is. In tight turns, I can lean my bicycle to about 45 degrees, and I get it leaned over that far by countersteering.
Nope. Any good bicycle rider steers just like a motorcyclist does--he countersteers, especially at high speeds. I'm a retired Cat 2 roadracer (and still put in 5000 miles a year on a bicycle), and I, and everyone else I knew who raced, steered by countersteering, not by weight shifts. Just because you can steer a bicycle by shifting your weight doesn't mean that's the best, or fastest way to do so.
#26 Unread post by Sev »
Countersteering is just a way to shift the weight. It tips the bike and that acceleration towards the ground is what makes you turn.
Case in point, today my friend and I were riding a curving road, couple of long wide sweepers on the highway (120kmh). I did two things.
1) countersteered normally and leaned into the turns a little.
This resulted in normal turning which is to be expected. Because that's how we're taught to do it.
2) I kep the bike completely vertical (with my friend riding behind me to confirm it) and shifted my weight to the inside of the turn.
Bike turned sharper then it did with countersteering (because I was putting more weight on the inside, within a second I had it modulated and was turning back and forth just fine by leaning off either side of the bike.
Countersteering is simply a means of tipping the bike. Once you have shifted the weight to one side or the other the bike will start to turn. That is what countersteering is, a shifting of weight.
And I didn't say it was the BEST or FASTEST way to turn a bike, but it does work, indicating it is not a function of cupped shape wheels. Otherwise I could lean way over on my bike but keep it vertical and not turn at all. This did not happen.
sapaul
#27 Unread post by sapaul »
The No BS (Body Steering) Machine
The Correct Brothers
It shouldn't be alarming to me that riders still question how to steer their motorcycles but it is. Apparently, even after 90 years when it was first observed by the Wright brothers some confusion remains on this subject . Yes, their first engineering attempts were as bicycle manufacturers; the very observant brothers determined that tandem (one wheel in front of the other) wheeled vehicles counter steer. That was and still is correct.
Sources Of Confusion
It is easy to see how confusion arises on the subject of steering for anyone of us who started their riding on pedal bikes. The steering is so light on a bicycle that riders have difficulty in separating the shift of their body mass (leaning into it) with the slight effort it takes to countersteer.
Further confusion arises from word of mouth advice on riding. I have even seen articles in usually credible national magazines extolling the virtues of body mass type steering. Body Steering as it is called. I have surveyed thousands of riders on this point. Most riders still believe that some of the steering is being done with their body mass or weight shift or pressure on the motorcycle's tank or pegs. Their estimates on how effective these are in getting the bike to turn range anywhere from 10% to 90%, some believe all of it is weight shift.
Swoopy Steering
If it weren't so grim, it's almost comical to watch a rider who does not understand how steering is accomplished. You can see them riding down the freeway trying and failing to change lanes by body steering and still appear cool while doing so. I have seen it dozens of times. It goes like this. The rider does a very swoopy upper body swing in the direction he wishes to go but for an agonizing moment (to me) nothing happens. There is a
perceivable lag between the upper body swoop and the bike's deflection from its original course. How terrifying it must be to find that the bike doesn't instantly respond.
Stiffen To Steer
Following that is a stiffening of the rider's upper body. Only then does the bike respond and change lanes. You see how this works? The rider's body is positioned off-center, from his swoop, in the intended direction of the lane change. The stiffening on the bars creates the countersteering action, because he has either pushed on the inside bar or stiffened and pulled on the outside one or a combination of both. This stiffening is actually a mild panic reaction. Many riders have simply learned to live with the lag and to think it is how their bike handles. That is false, a motorcycle responds almost instantly to countersteering.
Vague Technique
Riders have a number of ideas, which are vague and hard for them to describe, on just how their weight shifting accomplish this so called body-steering. "Throwing" their upper body mass to one side or the other (the swoop) is one. Some say they just push down on the inside peg. Some say they pull the bike over with the outside leg against the tank. Some say it is a combination of two or even all three of the above methods. Do they work?
I'll leave it up to the tech boys to figure out the WHY of motorcycle counter- steering. Their job should be to provide a simple demonstration of how it works. The fact is that countersteering is still being argued in the halls of learning with slide rules, Physics formulas and calculators. Many theories exist but no conclusive statement that I know of as to why has yet been reached. Argue on boys.
Clear The Issue
My job is to make riding simple and clear up conflicting information that a rider may have on the subject of riding. Any confusion translates into reduced control, as in the lag from swoop to lane change, and confidence, as in the bike won't do what I want it to, when I want it to. Riders don't like the uncertainty and love confidence.
I decided to make this steering issue, body vs counter, very simple and very plain. I reasoned that anyone who could see how it works and experience the real steering procedure would have dramatically improved their chances of survival against the perils of 21st Century Earth street riding. Steering must be done and done quickly if a rider has any hope of confidently neutralizing those perils.
Expert Opinions
I was actually in a deep confusion on this subject of body-steering myself. Riders the caliber of Eric Bostrom have told me that they do it to some degree to help steer. Freddie Spencer has made a statement to that effect and of course Reg Pridmore has made it the banner for his CLASS schools for 15 years. Jason's STAR school has been written up as teaching body steering as well.
With great to good credentials like that it should be so, and even I was a little shaken in my certainty. Maybe there was something in it after all. I hate to miss anything.
The Experiments
For my part, experimenting with pressure on the pegs, the tank, adjusting my body mass and combinations of all three on the bike resulted in nothing I would consider steering. In other words, something that could be used in an emergency maneuver or to aggressively flick the bike into a corner or through a set of esses.
Eventually I arrived at a potential solution to my questions that would eliminate my opinions and/or misunderstanding on the subject.
The Solution
Make a bike that has two sets of bars. One set as normal, the other set would be solid mounted to the frame so they were not connected to and did not rotate the forks. This, as my theory went, would answer the question. And it does.
The Machine
Taking one of our Kawasaki ZX 6Rs and solid mounting a set of bars 8" above the standard ones would positively isolate the various body shifting from the countersteering. If body-steering had any effect it would be simple to show it. I created a bike with that setup.
One necessary detail was to mount an additional throttle on the upper, solid mounted, bars so the bike's stability could be maintained as the user rode down the road. So we wound up with two sets of handlebars and two operating throttles on the bike.
MachineDirty Exceptions
Before I go any further, I want to address off-road motorcycles. An off-road motorcycle will easily steer by pressing down on the inside peg, and in conjunction with shifting the upper body mass, will go over pretty easily . Still not what I would call good control but it can be done fairly efficiently.
Again, I am not a true tech guy but it occurs to me that the small contact patch on knobbies or dual sport tires and dirt bike steering geometry, which is not intended to provide an enormous amount of stability at speed, contribute to the reasons why steering results from weight shifts to the degree it does on a dirt bike.
No Body Steering.
At this writing, we have run nearly 100 riders of all experience levels on this double barred bike. It has made believers out of every single one in the actuality of countersteering of course.
At 20 to 35 mph, no matter how much you tug or push or pull or jump around on the bike, the best we saw was that the bike wiggled and became somewhat unstable. Did it turn? Not really. Would it turn at higher speed? Absolutely not.
The best result was one of my instructors. He got into a full hangoff position and was able to persuade the bike, by jerking on it, to start on a wide, wide arc in the paddock at Laguna Seca, a piece of asphalt that is about 500 X 800 feet. Like turning an oil tanker ship, start at noon and be on the turning arc at around 1:00 PM. It wasn't very smooth and it wasn't very effective.
We now call this bike "The NO BS Bike". There are no doubts in anyone's mind after they ride it that they have been countersteering all along. No doubts.
You can hear riders, who believed in the body-steering method, laughing in their helmets at 100 yards away once they get those solid mounted bars in their hands and try to body-steer the bike. They just shake their heads. No BS.
Dangerous Misconceptions
Now if you want to look a little further into this, what you will see is this; riders who still labor under the misconception that they body-steer are devoting themselves in a system that can do a great deal of actual harm.
Firstly, it is seriously misguided to add an additional series of actions to the steering process. When it is quick, critical steering that is needed to avoid something, that lag I have observed so many times in street riders, could cost you your hide.
Adding 2/10ths to 5/10ths of a second to the steering procedure at 60 mph means that you have just gone another 18 to 44 feet down the road before you started to avoid that muffler lying in your path. Kids, don't try this at home.
The way things are going there will be warning labels on motorcycles in the not too distant future...
WARNING: THIS VEHICLE COUNTER-STEERS. IF YOU DO NOT UNDERSTAND COUNTERSTEERING DO NOT RIDE. SEEK THE HELP OF A QUALIFIED PROFESSIONAL INSTRUCTOR!
Bull Steering
Another recognizable error, resulting in excess effort used to steer the motorcycle, is the attempt to turn the bike by bulldogging the bars. An interesting combination of pulling up on one and pushing down on the other rodeo style, like bull wrestling. No, repeat No, steering results from this. None, zero, nadda, niente. Riders who think they can twist the bike into a turn in this fashion simply have another false idea and get tired.
The Bottom Line
Steering a motorcycle results from the process of pushing the inside bar forward, the same angle and direction the forks rotate in the steering head bearings. You can also pull on the outside bar. You can do both push and pull. That is what turns it, that is all that turns it with any degree of accuracy, efficiency, quickness or smoothness.
That and only that, No BS.
Keith Code
Keith Code can be found teaching at the Californian Superbike School in between wacky science projects. See more at www.superbikeschool.com
vBulletin v3.5.3, Copyright ©2000-2006, Jelsoft Enterprises Ltd.
#28 Unread post by Sev »
But the reason that turns it, is because that shifts the weight to the inside of the turn causing you to accelerate towards the ground and forward at the same time. This is a turn.
If you shift the weight in an efficient manner using the handlebars and counter steering the effect is much easier, and much more pronounced, however simply leaning off the side you want to turn to will also cause a turn, though it is MUCH more difficult to turn accurately in this manner.
Countersteering is simply a means of inducing lean.
sapaul
#29 Unread post by sapaul »
Quite frankly, I do not care so much about the science involved but more about how to make it happen. When I am with an instructer, this is what we discuss and put into practice.
#30 Unread post by Sev »
Ahhhh, that is fair, it really is the more important part isn't it?
