Water injection has a purpose in high compression, hot, turbocharged aircraft and racing engines. Those engines run with much smaller detonation margins than a properly designed passenger car or motorcycle engine. If a car needs water injection, it's either a race car or a race car disguised as a production car. Besides that application, modern intercooled turbos used in normal cars don't require water injection.
I remember that J.C. Whitney used to sell a water injection kit in the snake oil section of their catalog (along with hp boosting spark plugs). I remember because my goofball brother actually bought one for his '66 Mercury station wagon
I'm trying to remember what car came stock with water injection.... some old (early 60s) oldsmobile... lemme look...
"In 1962 and 1963 Oldsmobile built a turbocharged version of the 215, the Turbo Jetfire. The small-diameter turbocharger was manufactured by Garrett AiResearch and produced a maximum of 5 lb (0.34 bar) boost at 2200 rpm. The engine had 10.25:1 compression and a single-barrel carburetor. It was rated at 215 hp (160 kW) @ 4600 rpm and 300 ft·lbf (406 N·m) @ 3200 rpm. The high compression ratio created a serious problem with spark knock on hard throttle applications, which led Olds to use a novel water-injection system that sprayed small amounts of distilled water and methyl alcohol (dubbed "Turbo-Rocket Fluid") into the combustion chambers to cool the intake charge. If the fluid reservoir was empty, the engine's timing would be mentally challenged to avoid engine damage. Unfortunately, many customers did not keep the reservoir filled, or had mechanical problems with the turbocharger plumbing." -- Wikipedia.
Skier wrote:Actually, guys, small amounts of water poured into a carb has good effects for the combustion chamber.
Can we use your bike to define "small amounts"?
Certainly. I've already sucked Seafoam through the vacuum inlets on the carb boots when the bike was running. We'll find out exactly how much is too much.
... on the Katana.
idk if you've noticed or not, but i made this thread 3 days ago and this will be my first reply......my hard drived fried! damnit, i lost so much crap....i finally installed some crappy version of windows and i'm back up.
but anyway, when i said pour water into the carborator.....i meant...
"do i have to pour water ANYWHERE into the bike?"
You only live once, abuse it!
and Live Life For Today As Tomorrow May Never Come --BadAss
Dirtytoes wrote:P.S. really off topic but am i supposed to pour water anywhere into the ex500? .....i.e. in a car, you have to pour water into the carborator....is it the same for the ex?
I don't check the website for ONE day - and I miss out on awesome information like this! My truck doesnt have a carb...but im sure I can get water in the FI system somehow....
Those of you who think you're cool annoy those of us who really are! 8)
