should i get u crashed bmw?
Andrew
#21 Unread post by Andrew »
The pictures aren't showing up for me, but from the sounds of it, it probably wouldn't be worth the work required to get it running. There are a lot of good deals out there on BMWs...you just have to look.
2004 BMW K1200RS
[img]http://www.bmwlt.com/forums/images/smilies/BMWsmile.gif[/img]
Flting Duck
#22 Unread post by Flting Duck »
I've parted several K's out(including a 1986 K100RS) and built one from three wrecked bikes.
I doubt anyone would've tried to start it since all of the oil would've leaked out immiedately - unless they're dumb as a post.
If the steering head isn't bent(They are very sturdy up front) then it would not be that hard to get it going - but it would be a labor of love , not to make money:
Fork tress(which are probably busted: $150 (i've got some)
Forks: $150-200
Fender: $35 (I've got one from an 86 I could sell you)
Faring: Replace it with a fairing from another K75 or K100 - much easier than trying to source a good main fairing and fairing lower.
Timing cover: $50
Frame: $150 (i've got an 86 K100RS with a clear title)
Valve cover: $35-70 depednig on if you buy a scraped one or a clean one
Can't tell from the pciture but it may need a new lower timing sprocket and exhaust cam - hard to tell from the picutre but they'tre probably OK
As a parts bike, it's probably worth $500-700 - done right, you could EASILY get $1500 out of it - depends on mileage though for drive train and rotors.
Where is it? I might be interested.
93 BMW K1100LT "The Green Hornet"
91 BMW K100RS 4V "Kato"
IBA #17739 (SS1K, BBG, 50CC)
sidecarguy
#23 Unread post by sidecarguy »
thats the thing it would be easier to fix
in the us, as it is i'll see if i find parts .
if i find then maybe i'll give it a shot!
it is in guatemala, central america
and that is south of the border (of mexico).
go to www.freewebs.com/4x4scout
if u can't see the pics.
jean b.
jawa350 w/sidecar
suzuki rv90
yamaha xj650 seca
floridasroadkill
crashed BMW
#24 Unread post by floridasroadkill »
I have a garage full of BMW parts .When you know the model let me check what I have for you.
Und ewig rennt die Gummikuh
sidecarguy
#25 Unread post by sidecarguy »
like i said ...ok it is a k100rs 1986
lemme know ok...i take it u in florida?
jean b.
jawa350 w/sidecar
suzuki rv90
yamaha xj650 seca
