Looks like the final blow has been struck on the Kat. I dropped a cylinder head nut into the cam chain area when taking the head off. No problem, I've fished stuff out of there last time the head was off, without a problem.
Nope, it fell even further into the motor. So I drop the oil pan, thinking it fell through or I'd be able to see it. Nothing in the pan or anywhere I can see.
So I pull off the jugs to get a better view at things. Two or three hours of poking, prodding, swearing and probing later, I have no idea where it went. That means it is either stuck on a weird ledge somewhere in the lower end or it dropped back into the transmission. Either way, it's not coming out without splitting the cases entirely, which is more than I'm willing to do for the bike.
Now the question is if I want to go big with that 750 swap, or recoup my money to put into... well, probably paying back some loans a bit quicker. I'm not hurting for cash, so I may just see if I can pick up a wrecked 750 at some point and go to town with a swap.
Stupid Katana.
Oh well, I got the chain clean on my 599 (overdue), oil and filter change on my Civic (overdue), valve lash set on the Civic (overdue) and washed the cage, as well.
