My bike is so hard to get started!! any tips?
Puyopop
#21 Unread post by Puyopop »
hes right though a CC is equal to one mL. Although 200 cc's isnt two litres if thats what he meant its only 0.2 litres.
intotherain
My Motorcycle: FZ6
#22 Unread post by intotherain »
Puyopop wrote:hes right though a CC is equal to one mL. Although 200 cc's isnt two litres if thats what he meant its only 0.2 litres.
Yeah i Meant .2 liters. 2 liters would be huge.
#23 Unread post by Sev »
Stroke X Bore = Engine Capacity, the greater the capacity the more "potential" power there is.
Actual power comes down to so many factors it's not even funny. Starting with gas type, cylinder configuration, 2-stroke or 4-2troke, the intake/exhaust timing, compression ratios (related to gas type), transmission type and gear, final drive type and gearing.
And then you can move around where the hp is produced in the rev range, but all you can do is move it. If you increase top end power, you lose bottem end, or vice versa.
You can even start to factor in weight if you wanted, but that's basically irrelevant.
FlyinRegie
Real Name: Regie
My Motorcycle: 2000/Suzuki/SV650s
#24 Unread post by FlyinRegie »
Hello,
Try starting it without using the full choke (no throtle), use just some choke (few milimeters), your bike can have its own starting character.
Good luck!
Carburetted :)
'00 Suzuki SV650s
