Helmet Neck Snap and other questions
Shorts
#21 Unread post by Shorts »
olebiker wrote: Many of us died or were injured in highspeed crashes.
So when was your rebirth?
olebiker
#22 Unread post by olebiker »
:roll: :roll: :roll: :roll: :roll: :roll:
Shorts
#23 Unread post by Shorts »
Dude, it was a joke. I guess I needed all the emoticons in there.
Mental note, olebiker doesn't liked to be joked with.
olebiker
#24 Unread post by olebiker »
Gotcha!
dablade
Real Name: Perry Crowell
My Motorcycle: 2005 Yamaha FJR 1300, 2004 GL1800 ABS
#25 Unread post by dablade »
It is your right in Florida to not wear a helmet.
Signed,
Darwin
dbrann11
#26 Unread post by dbrann11 »
That study about head impacts shows that ~50% are on the front lower left and right side... right where a full face covers.
I think the whole neck snapping helmet scenario is very similar to the steel toed boots myth. If you drop something heavy enough to bend steel and pinch your toes or cut them off, well you are going to lose you toes anyway without the steel. If you hit your head hard enough, or whip your head hard enough to break your neck, with a helmet, you're probably not going to make it without the helmet either.
