Mine has a brand new chain and sprockets but I will check out the other stuff just in case. The things is, it was smooth before I changed the handlebars.Gummiente wrote:Coach, I'm wondering if maybe you should look at the bike itself to get rid of the vibration problem. My girlfriend's '01 Vulcan 800 Classic is s mooth rider but gets buzzy every once in awhile - I cure it by lubing and/or adjusting the rear chain. Maybe you could do that and also make sure the wheels are still in balance and do a torque check on all the engine mount, handlebar and footpeg mounts to make sure nothing has come loose which would cause vibrations.Coach wrote:The rope has helped some, but I want to fill the lower portion with BBs to see if doing both helps even more.
Throttle hand getting numb?
- Telesque
- Legendary 500
Is it still smooth if you put the old one back on? You didn't, you know, go and drop the magical anti-vibe piece on the garage floor or anything, did you?Coach wrote:Mine has a brand new chain and sprockets but I will check out the other stuff just in case. The things is, it was smooth before I changed the handlebars.Gummiente wrote:Coach, I'm wondering if maybe you should look at the bike itself to get rid of the vibration problem. My girlfriend's '01 Vulcan 800 Classic is s mooth rider but gets buzzy every once in awhile - I cure it by lubing and/or adjusting the rear chain. Maybe you could do that and also make sure the wheels are still in balance and do a torque check on all the engine mount, handlebar and footpeg mounts to make sure nothing has come loose which would cause vibrations.Coach wrote:The rope has helped some, but I want to fill the lower portion with BBs to see if doing both helps even more.
-'95 Honda VT600CD / 'Shadow VLX Deluxe'
-'84 Ruestman WTF606
"[The four stroke] cycle is basically this -SUCK, SQUEEZE, BURN, and BLOW." -Dan's Motorcycle Repair Guide.
http://www.dansmc.com/MC_repaircourse.htm
- DustyJacket
When I swapped my "tricycle" bars for CityX bars, there is an added crosspiece. The net result is that the bars must flex less, so more vibration is transmitted to my mirrors. A lot more.
www.bacainternational.org
- dr_bar
- Real Name: Doug
- Years Riding: 44
I have a pair Kuryakyn ISO® Grips on my Virago 1100. Now that bike has vibration issues, lol, but those ISO grips are great. I believe they also have a throttle rocker for them as well.
But this might actually be a throttle lock???
I have a feeling it's just the difference in the bars. They are totally different. The old bars were the stock buckhorn style bars that attached by bolting them into the risers which bolted to the bike. The new bars are drag bars off of a Vulcan Mean Streak and get bolted directly on without separate risers. So they are slightly lighter, definitely more rigid, and no longer have the added mass of the risers in between. I'm going to try the BB idea tomorrow.
- Regular
- Wizzard
- Legendary 1000
I find that this happens to me most often if I am gripping the throttle too hard . I have a throttle rocker around here somewhere that I am going to use to try and see if it makes any difference .
My risers and bars are rubber mounted and I have little vibration . So I keep thinking that it is me or something that I am doing that I can change .
Kind regards, Wizzard
