Scraping Pegs
- ZooTech
- Legendary 3000
- Years Riding: 18
Early on, no, but once the basics are mastered it wouldn't hurt to practice low-speed peg scraping during tight circle maneuvers in a parking lot. If you get used to the aggressive angles and know what the hard parts sound like when hitting pavement you'll be less likely to freak out in the event an evasive maneuver becomes necessary later on when you're out on the road and more likely to act appropriately.bikeguy joe wrote:I don't think "scaping the pegs" should be a priority for the newb however.....
- bikeguy joe
- Legendary 300
- ZooTech
- Legendary 3000
- Years Riding: 18
Interesting question...iwannadie wrote:if you had a bike on a dyno type setup with the engine revved and the tires spinning could you lean the bike in theory?
While the wheels would be spinning (assuming you're suggesting that the dyno would artificially spin the front wheel) thus acting as gyroscopes, the sprung weight of the bike would NOT be moving and therefore would not be contributing it's own momentum to the equation. So, essentially what you're asking is if the gyroscopic forces from the wheels would be sufficient to hold the bike in a "static turn" to which I would have to reply with a resounding "no".
be cool to see someone try that too though even if its sure to fail ha.ZooTech wrote:Interesting question...iwannadie wrote:if you had a bike on a dyno type setup with the engine revved and the tires spinning could you lean the bike in theory?
again it amazes me how a bike can lean, i was pushing my kat and went to lean it and had to use all my strength to keep it from falling. but sit on it go not even 10mph and it will lean nearly scrapping pegs without a problem. guess that little foreward momentum makes a big deal.
03 katana 600
- bikeguy joe
- Legendary 300
- ZooTech
- Legendary 3000
- Years Riding: 18
Yeah, it's that forward momentum that translates into downforce when taking a turn. Add to it the rotating mass of the wheels and tires for lateral stability and...well...it's just physics.iwannadie wrote: again it amazes me how a bike can lean, i was pushing my kat and went to lean it and had to use all my strength to keep it from falling. but sit on it go not even 10mph and it will lean nearly scrapping pegs without a problem. guess that little foreward momentum makes a big deal.
- bikeguy joe
- Legendary 300
