bike suddenly not starting... could it be the starter motor?
Deletor
#21 Unread post by Deletor »
Assuming all your connections are good, if you are getting a single click it may be the starter solenoid itself. I used to rebuild alternators and starters for cars. As the solenoid gets older the contacts inside tend to start sticking which will lead to a single audible click. Never played with bike starters but if its anything like what I used to work on you may be able to take the solenoid apart and replace/clean/flip the copper contacts over to get some more life out of it.
gerpena
#22 Unread post by gerpena »
Deletor wrote:Assuming all your connections are good, if you are getting a single click it may be the starter solenoid itself. I used to rebuild alternators and starters for cars. As the solenoid gets older the contacts inside tend to start sticking which will lead to a single audible click. Never played with bike starters but if its anything like what I used to work on you may be able to take the solenoid apart and replace/clean/flip the copper contacts over to get some more life out of it.
i took a meter to the solenoid output and when i tried to start the bike, the solenoid would output ~12.3 volts.... isint this evidence that the solenoid itself is working perfectly or am i missing something?
1983 Honda Nighthawk CB550SC
"You start the game with a full pot o' luck and an empty pot o' experience... The object is to fill the pot of experience before you empty the pot of luck."
