Synthetic oil in motorcycles
- floatsmyboat
- Veteran
- paul246
- Legendary 500
It depends on the piece of equipment and time of year. We get all extremes of temperature here, from the high 30's (celsius) to the sub 40's. In the motorcycles I'll use Rotella 0W40 synthetic in the cold weather, sometimes blending it with Mobil 1 15W50. I use the 15W50 Mobil 1 in the wife's V-Star all summer. I also use Redline 10W30 and 10W40 as well in the low capacity and high revving machines. Redline is pricey but an extremely good group V polyoester based synthetic.floatsmyboat wrote:Paul, what brand do you use?
Greg O.
Honda XR650L Dual-Sport
A number of years ago, 0W-40 was heavily advertised for use in heavy machinary, in the cold temps we get in parts of Canada.
I tried it in a diesel engine with disasterous results. The oil didn't help seal the cylinder walls whilst cold and allowed diesel to run straight passed the pistons and into the sump. In minutes I had a mix of diesel and very expensive oil blowing out of the breather.
Back to 10W-40 and no probs.
Would a 0W-40 invalidate a bike warranty?
- oldnslo
- Real Name: Lamont Cranston
- Years Riding: 20
- My Motorcycle: Year/Make/Model1983 Yamaha Seca 900
Regarding the energy efficient starburst on oil bottles, Mobil I in 15-50 doesn't have one, last time I checked, anyway. Regarding moly content, in a test a few years ago by MCN, Honda motorcycle oils contained more of it than any other bike oil. It would be interesting to see something more current.
John
"83 XJ900RK
"83 XJ900RK
G'day Guys and Gals
In my "new" BMW K1100 I run full synth in the engine and dino in the trans and final drive. I still do my engine changes every 5000km, bugger the cost as I think it is of benefit.
My mate with a 850 Le Mans Guzzi. He just had to pull the head off one cyclinder because the slide in the carb broke and spat the bit into the head. He runs his bike on full synth. After 99,100kms, the cross hatching on the bore is still visible and no marks at all inside. All tolerances are well within specs.
Still, different strokes for different folks. Run what you feel comfortable with and remember to change on the manufacturers recommended interval.
Ride safe
Fearless
Ride safe
Fearless
- flynrider
- Years Riding: 30
Oil tends to be kind of a religious subject on motor forums (car,bike, airplane...). I tend to think that changing the oil regularly and riding the bike regularly will have a lot more impact on engine life than the brand of oil used. I took several bikes into the 60 and 70K mile range just using plain old dino oil that was changed frequently. They were all running strong when I got rid of them.Fearless wrote:Still, different strokes for different folks. Run what you feel comfortable with and remember to change on the manufacturers recommended interval.
Bikin' John
'93 Honda CB750 Nighthawk
I run Redline 10w40 full synthetic in my SV1000. Very expensive oil but well worth it. The bike is much smoother while running Redline and operates cooler as well. It feels like it can go through the rpms much easier. I've run a couple different full sythetics due to lack of Redline at the shops, always have to order it. Everytime I put in others, it felt like total crap compared to this stuff. Each time I've run the different sythetic, I've drained it within 500 miles to put Redline back in it.
Brian
'03 Suzuki SV1000
'03 Suzuki SV1000
