CNF2002 wrote:You shouldn't grip your brake all the time. You could inadvertently give yourself a nice full panic brake at high speed.
How did you break your brake lever? Just by normal use? That's a much needed recall if I ever heard one! I just don't understand your comment:
"mine bent since i barely touch the brake lever while im on throttle."
Why would you be touching the brake lever when you are throttling up and how would doing this cause it to bend?
You can get a replacement lever for your bike for like 15 bucks.
not broken... just feels bent.
i dropped my bike again when i tried to remove the rear stand on my own. i don't see any new scratches and i will never attemp to try to remove/put the stands on my own ever again.
then when i took it out the next day... i noticed something different about my brake levers.
it doesn't look bent... but i defnitely felt a significant difference on my hand position.
it's important to be able to reach the brake while on throttle.
it's bad to quickly let go of the throttle so it's bad if you can't reach the brake lever while on throttle.
and i dunno... to me... it feels like i have less chances of grabbing the brake when i already have fingers on it. i feel like i will squeeze it more than likely instead of grab it. on all the emergency braking i have done, i haven't locked the front brake yet.
oneida suzuki has my OEM levers for $50... that sucks... for $30 more... i could already get an AM shorty.
