Close, but no cigar.MetricRider wrote:The main thing to remember here is that above 98 F, your body is not emitting heat, it is absorbing it. That raises your core temp, leading to heat exhaustion/heat stroke. Having a jacket on, mesh or otherwise, in weather above 98, regardless of the humidity, is always going to be better for you because it provides an insulating layer and protects you from the sun. Below 98, a mesh jacket will still keep a t-shirt wet with sweat wet and cooling you longer than the t-shirt alone. Only if you are sitting in traffic or standing around would wearing a t-shirt be better than wearing the mesh.
That's not so much that it keeps you cool, but that it's the only pre-sunscreen way to keep yourself from roasting alive due to UV rays.Dichotomous wrote:depends on how much insulation and such there is. Nomadic desert inhabitants are in full coverage, keeps the inside to only 98deg, considering they've figured this out and perfected it over thousands and thousands of years over there, its less open to debate
A welding hood took the place of the straw hat when actually welding, there are lots of other things to do out in the sun. The welding was a small part of my job when in the field. The straw hat is like the mesh jacket in alot of ways, it looks foolishly hot to some and smart to others.Nibblet99 wrote:ok this made me laugh my "O Ring" offBeach wrote:I used to soak my welding cap in ice water and wear it under a straw hat on job sites.
Welding and straw hats just doesn't seem like a good mix, whatever way you cut it
TMW
Privacy Policy - Forum
Privacy Policy - Terms
and Conditions
Follow us on X / Twitter - Facebook - YouTube - Pinterest - Instagram - News RSS Feed |
