SausageCreature wrote:snip.......
Why would you not? When I want to decelerate at a slower rate, like when a light ahead changes to green and I have to wait for a stopped car to get going, if distance allows I let air resistance slow me down and the engine idle.
I don't see how engine braking can give you any more braking power than your rear brake. I guess if you drop it down a gear or two the engine pulsing might act as a sort of ABS, but under normal conditions why not use your brakes, being as they are specifically designed for the purpose?
Why would you not? Well, when you put your vehicle into "neutral", which is what you are essentially doing when you pull the clutch in, you are taking away any control of your bike, other than braking and steering. So, why not just either shut off the throttle, and if you aren't slowing fast enough, drop a gear or two? That way you are staying within the power band in case you need power to move out of the way quickly (God!! how many times do we have to say this???)
But you are correct in saying that engine braking does not give more braking power than the rear brake, but remember, rear brakes are only 1 source of slowing/stopping. You also have your front brake andengine braking. So, add it up and you come to the logical conclusion that 3 sources of slowing/braking are better than 1, do you not?
Also, another thing about braking.
The front brake is more effective than the rear brake. Why? you ask.
When you apply the front brake, the bike's centre of gravity migrates foreward, the front suspension compresses and this puts more weight on the front wheel, tranferring the weight into increased pounds per inch between your tire and the road surface.
For those of you who believe that you should pull the clutch in and use the brake to slow/stop your bike, I would like you to try the following.
1: Take your bike to a street with next to no traffic.
2: Get up to the speed limit
3: Close your throttle and check to see how long (time, not distance) it takes to drop down to 10 MPH.
Repeat this with the only change being
4: Drop one gear lower and close your throttle again and check the time it takes to drop to 10MPH.
Repeat but do this
4: Pull your clutch lever in all the way and check to see how long it takes to get to 10MPH.
Finally, do this
4: Shift down and use braking at the same time to slow to 10MPH.
We would like you to post your results next time you come here.
Please??
