Oil
#31 Unread post by Sev »
That oil light is there to indicate oil pressure. The oil pressure is acheived through the means of a pump that is run off the engine. No running engine, no oil pressure, light comes on.
Once you start it up then the pressure builds rapidly and the light goes off.
The sight glass is to give you an "idea" of the level of the oil. You want it near the top in case something happens - you leak a little you burn a little, some just plain old dissapears. It's better to have a little too much (within those two lines) then not quite enough.
niterider
#32 Unread post by niterider »
(And I agree 100% with what flyinrider had to say about tire pressures.)
+1 more
1993 750 Vulcan
one seater
ear shave, pod filters
rear turn signal relocation
lowered rear 2" soft tail
horn relocation
SilentComposer
#33 Unread post by SilentComposer »
Thanks everyone, I really appreciate all the information.
SilentComposer
#34 Unread post by SilentComposer »
Well... I thought it was all solved.
Now when I go to change my idle speed I can't seem to settle it at 1250. When I try to adjust it, it either settles at 3000-2500 or keeps dropping until it stalls. I have tried adjusting it extremely slow... But the same thing keeps happening. My dad says the screw could just be wacky and that it's worn out so it slips when I put it near 1250. Any ideas?
mgdavis
#35 Unread post by mgdavis »
I sounds like it sat to long with fuel in it and the carbs gunked up. The next step I would take would be giving them a good cleaning.
'07 Suzuki V-Strom DL650
Molon Labe!!!
#36 Unread post by Sev »
+1 on the clean your carbs. UGH, I hate cleaning carbs :P
mgdavis
#37 Unread post by mgdavis »
:laughing:
Don't let Sev scare you, it's not that bad. Get a manual, take your time, label everything. Pictures help. When I did mine, the worst part was getting the carbs out of the bike. It was all gravy after that.
Molon Labe!!!
#38 Unread post by Sev »
mgdavis wrote::laughing:
Damn boots, lol!
I just hate the smell of carb cleaner mostly.
SilentComposer
#39 Unread post by SilentComposer »
So I will definitely need the service manual for this one, right? I'll order it from Kawasaki ASAP.
Thanks again everyone.
scan
#40 Unread post by scan »
From the scan school of avoiding big work - when I got my bike it was gunked a bit in the carb department. Now keep in mind, my bike hs 4 carbs, so a rebuild did not sound good to me. So I tried the several fill ups of premium and rode the bike in the higher RPM (not red-line or anything like that) as much as I could. It cleared itself. I do not think that will always work, but if you have some time before you can get that work done, it might be worth your time to try to force it to clean itself. If something is jammed open or closed, that might not do a thing, but if there is a little varnish built up, a few tanks of premium might just do the trick. I say premium because most premium has extra cleaners in it - also, pour-in carb cleaner might help, but I've never used that on my bike.
* 2003 Kawasaki ZRX1200R *
