The more I learn in class the less I trust my bike. Something as simple as a missed cotter pin (some of our forum members can attest to this) can mean the difference between an axle that stays on, or an axle that comes off... or a brake that works and a brake that doesn't.
Overtorque a bolt and it might snap or you'll ruin the threads, undertorque it, and it'll work loose. A change in tire pressure will halve the life of your tire... it goes on and on.
Right now we're learning to lace and true a spoked wheel. It takes a LOT of work, every spoke needs to be in the right spot, with just the right tension. A loose spoke will break and then break the ones around it. If the tension is wrong the wheel won't be true. Actually on the bike I'm working on a wheel is considered true if the rim doesn't deviate by more then 2mm. Think about that for a second, 2mm difference either side to side or from the hub to the rim before a mechanic will even look at it. Imagine what kind of a hop that'd make in your riding as it bounced up and down.
In class the acceptable limit is 0.3mm and every time you adjust one direction (lateral or radial) it messes with the other direction. But it gets a little closer each time you re-adjust it. And I'm already picking up some neat tricks.
I've actually just come from class where I've successfully dissasembled, then reassembled a complete wheel, AFTER taking it off the bike.
So: put the bike on a stand, jack up the back end, remove the axle and brake, pull off the wheel. Let out the air, break the bead, remove one side, pull out the tube, remove the other bead.
I'm now ready to dissasemble the wheel. Draw out the lace pattern, determind the offset (distance from one side of the hub to one side of the rim), mark the point on the hub that is directly in line with the valve stem.
Then remove all the nipples (nuts) that hold the spokes in place. Then remove the spokes keeping the inside and outside spokes separate.
Then... do it all in reverse, make sure not to pinch the tube with your levers or you'll be pulling it out and putting in a new one. My wheel was witin .15mm in both radial and lateral runout. Well within specs, we keep having it impressed upon us, that if we're going to do it... we better do it right. Right now I'm at the point where I can put final pressure in the tube and mount it back on the bike. Then I need to check the final drive chain slack make sure all my nuts are torqued into place, and finally look over the rest of the bike to make sure everything is to spec.
It's amazing how much work goes into a simple check, but attention to detail is the code of the class, and we've taken it to heart.
I'm hoping that learning like that, to make sure everything is perfect will be noticed once I finally start working and give me a good reputation with customers, if not with management
