Trapped Inside : Dreaming of Adventure
Outlaw
#41 Unread post by Outlaw »
Hey Brian,
Its good to see you've gotten underway! :D I'm glad the bars seem to be working out for you. I'll be following your progress, as I hope to do something similar some day. You should be passing within about 75 miles of me within the next day or two (Effingham, IL is 75 Miles south)
Enjoy!
Doug
scan
#42 Unread post by scan »
I talked to -holiday today. He has made it to Kansas (half way through) as of tonight (Sunday 7/23). I'll let him tell his story in his own blog, but for now he is still making miles across this country.
When you get back to your blog, just wanted you to know it was great to have you as a guest here in town. You are welcome any time.
* 2003 Kawasaki ZRX1200R *
ZooTech
Years Riding: 18
#43 Unread post by ZooTech »
-Holiday won’t have access to an internet connection this evening so he asked me to update his blog a bit with what happened over the last couple of days.
He arrived at Loonette and Scan’s house in Yellow Springs on Thursday, a day earlier than planned. I met up with him and Loonette at Competition Accessories in Springfield, Ohio right after work on Friday, so we were able to get a bit of riding in before tbonee and family (and his 1-hour-old Vulcan 900) came up from Cincinnati. The following pics are from Caesar Creek state park which is S.E. of Dayton:
Later that night……a jam session:
It rained pretty hard Friday night, and we were all up ‘til 3:00am kickin’ it old skool. We finally departed around 10:00am after much appreciated hospitality from Scan, Looney, and family. “We” meaning Scan, tbonee, -Holiday, and myself. We left Yellow Springs and headed for the Ohio River via Cincinnati where we picked up Route 50 which would take us all the way to St. Louis.
Some pics of our first pit stop just west of Cincinnati:
tbonee’s 2-day-old Vulcan 900, freshly baptized on the ride through downtown Cincy:
It rained off and on in S.W. Ohio, but cleared once we crossed over into Indiana. Scan and tbonee had other obligations, so we parted ways in Versailles:
Once underway again, -Holiday and I picked up the pace in order to make up for us all sleeping-in a bit later than planned. We crossed the lower part of Indiana in record time, despite the slow-going nature of Route 50. We ran at a sustained 95mph for a good part of the time, crossing into triple digit range during some “now-or-never” passes. Part of the route took us through what appeared to be a state forest, with plenty of high-speed twisties and some decent elevation changes.
Once over the border of Illinois we stopped so I could….*gasp*….put on the Skid-Lid I brought since I was under the impression that Illinois was a helmet-law state. Luckily a couple bikers rode by with their hair a-blowin’ so I gladly put that thing back in the saddle bag! We didn’t get too much further when the unfortunate finally occurred….-Holiday’s bike started bleeding. The oil pump cover, which had been damaged along with the engine case by a previous owner (mentioned earlier in the blog), was leaking far worse than before. I can only speculate why the problem escalated, though I’m sure the high-speed run through Indiana didn’t help. In any case, -Holiday’s right boot was covered in oil and it was unsafe to continue with the possibility of coating the rear tire with the slippery goodness. So, off came the cover along with a healthy application of JB-Weld so we could come up with a solution to get us up the road. The best I could come up with at the side of a busy highway was to coat the mating surfaces with RTV and pack the inside of the cover with a make-shift gauze (one of my socks). This helped only slightly but was enough to get us to a gas station in Olney, Illinois to take a closer look and assess our options.
I decided to try making a gasket with some duct tape, which actually seemed to hold pretty well (no drips at least), but was never tested at high-speed:
In the end, we were 150 miles short of our destination (St. Louis) with two hours of daylight remaining. The tiny lackluster town of Olney had a Super-8 motel, two auto parts stores, a KFC next door to the motel, and a 24/7 Wal-Mart a mile up the street. The decision was made to crash for the night and use the remaining daylight to attempt a more suitable repair to the cracked cover and gouged engine case. I had never had any success with the 2-part JB-Weld gel, which is what was originally used and had apparently broken down due to heat and contact with oil – but I had experienced success with the JB-Weld putty which comes in a tube and has to be kneaded. So, we purchased all the supplies at O’Reiley Auto Parts and checked-in to the motel.
After removing all traces of RTV, JB-Weld gel, and silicone (a futile repair attempt by the previous owner) it was time to remove all the oil residue. A quick shot of aerosol engine degreaser made short work of it and prepped the bare metal adequately for the putty. After most of a roll set up quicker than it could be applied (d’oh!) the results looked promising:
Keep in mind there was a roughly 1-1/2 x ¼” chunk of metal missing out of the engine case, and a hole in the cover itself big enough to pass a dime through! The JB-Weld epoxy putty supposedly contains metal dust and can withstand 300-degrees and pretty much most solvents and petroleum products. It was the best we could come up with at 7:00pm in the middle of B.F.E. and, the last I heard from –Holiday, he was west of Topeka, Kansas without a single drip.
This morning we made a run to the aforementioned 24/7 Wal-Mart and purchased a wrench to adjust the chain on his bike (and some sun block for my John Denver wannabe nose!). Apparently the shop that changed his tire neglected to replace the cotter pin in the castle nut on his axle and it crept forward causing the chain to contact the frame and swingarm. After sorting that out we parted ways at 10:00am. I had to be back in Marysville, Ohio by 3:00pm to fetch the kids with my truck so I spent all of Route 130 and most of I-70 running 100+mph. –Holiday’s goal was to make the Colorado border by sundown, but I believe he found Kansas little wider than expected so…….he’ll pick it up from here.
-z00t
P.S. Yes, I have many more pics of Friday night's "festivities" but am very much afraid that Loonette will dis-own me if I share them here! :laughing:
Z (fka Sweet Tooth)
#44 Unread post by Z (fka Sweet Tooth) »
Holiday it's good to see your already off on your trip, I'm looking forward reading about it as you post updates. I'm sorry to hear you had alittle incident but luckily Zoo was there with a solution.
T-Bonee nice 900! love it.
Zoo, no pictures of you?
2006 VTX 1300 R
ZooTech
Years Riding: 18
#45 Unread post by ZooTech »
Sweet Tooth wrote:Zoo, no pictures of you?
Actually, I'm in nearly every picture. Unfortunately the forum filter removes everything of an obscene nature. :roll: :laughing:
Z (fka Sweet Tooth)
#46 Unread post by Z (fka Sweet Tooth) »
:laughing: oh please...
2006 VTX 1300 R
roscowgo
#47 Unread post by roscowgo »
/me want kawi baaaad.
good deal on the trip. be safe!
-Holiday
#48 Unread post by -Holiday »
I woke up the other day and I had to check to see if I was still in the Mid west.
Let me see...
WallMart? Check!
All american cars? Check!
400 pound man wearing overalls pushing a cart full of HoHo's? Check!
Actually as I type this I'm in Hays, Kansas, which is almost exactly the half way point.
As Zoo mentioned, I arived at Loonette and Scan's Thursday night, a day early. They were nice enough to put me up for two nights, and were excellent hosts. I Friday I basically rested, caught up on some internet, then Loonette took me for a ride , until we met up with Zoo.
We went and got some iced cream, visited a cycle shop, and also had a scary moment when a deer jumped out in front of Loonette as we were coming up to a red light. She locked up her rear brake and missed it. I was behind her and watched this happened, and I think I almost ruined my pants. Deer are just one of those things you cant control.
I think Zoo covered most of the festivities of Friday night. I just wish I didnt look fat in those pictures! Uhg!
DAY 3 of riding
311 Miles
Anyway, now that I'm over that, Saturday, we got on our way. I have a few more pics to add to what Zoo posted:
Scan T-bonee Zoo and I headed towards Cinncy, then into Indiana. About lunch time T-bone and Scan had to head back so Zoo and I pressed on, tearing up the country side. Not many pics from that time frame because I was busy steering..
Then my bike had the issues mentioned above and we had to stop. Zoo did an awesome job of getting me patched up. If I ever get rich and decide to tour the world, I'll hire Zoo to go with my as my motorcycle mechanic :)
2000 Suzuki Bandit 1200s
Vespa Rally 200 in pieces
Loonette
Real Name: Kristin
Years Riding: 13
#49 Unread post by Loonette »
Nice to see that you're still alive out there. How's the repair job holding up? Hope the rest of your journey goes well - keep us posted.
It was great having our little TMW sleepover party. All these bikers in the house, and nobody even brought pajamas! :rocking: Thanks, Holiday, for dusting off the guitars with Scan. That's always fun, no matter how rusty everyone is. (my kids said that they didn't hear a thing! I'm amazed by that, 'cuz we were pretty loud sometimes).
Here's a group shot that my son took for us right before the men-folk took off on Saturday.
It goes, left to right, ZooTech, T-bonee, RNrider (a new TMW member, T-bonee's wife), Loonette, Holiday, and Scan.
2006 Mean Streak 1600
-Holiday
#50 Unread post by -Holiday »
Day 4
692 miles!
This was a long day. Zoo and I split ways after he adjusted my chain (in a non gay way). I wanted to put on some miles because my plan had been to do 500 a day and we had only done 311 the day before. I needed to feel like I was making progress, and when I looked at my map of the US, it looked huge, and it also looked like I had a LONNGGG way to go. I still do, but as I type this I'm half way there. Day 4 actually ended last night around 10, but was too tired to type this up.
Anyhow, I went through 90% of Illinios, all of Missouri, and 75% of Kansas yesterday. Kansas is freaking huge! I really didnt know it was that big!
I didnt even stop in St Louis, or Kansas City because it always fell at a time when I had just stopped. I did get a picture of the arch in st louis, but somehow it got deleted from my camera because I cant find it!
Here are some random pics i snapped yesterday though, mostly while cruising down the highway at 75 or so :)
I guess i did get one of st louis:
once i got past Kansas City, most of my day looked like this:
it was nice though in that the temps stayed in the low 80's.
at about 9pm it started to get really pretty on the open rolling plains:
finally at about 10pm it was time to stop. My butt couldnt take it anymore. Im not sure how those iron butt guys do it, but around 700 miles was enough for me, at least on this bike.
So after about 10 hours on the road by myself, I think I started to go kinda crazy. Somewhere after Kansas City I started saying in my head, "You're not in Kansas anymore....YES YOU ARE!...You're not in Kansas anymore....YES YOU ARE!!" Then eventually , and beyond my control, I started singing "Somewhere Over the Rainbow" in my helmet. Only Elvis style. It sounded right at the time....only 400 more miles...
At one point, I passed a car with a Pennsylvania plate. I got so excited that I pulled up next to him and waved frantically, then pointed to my plate and pulled up to show him that I too, was from Pennsylvania. He IMMEDIATLY pulled off the road onto a rest stop. Afterwords I figured out he must have though that I was telling him something was wrong with the back of his car. I was just trying to bond.
I guess I should just stick to a "thumbs up".
Well, its Monday morning, and I'm planning on getting myself just 320 miles to Denver today, then spending the night. Then I expect Tuesday and Wednesday will get me the rest of the way, barring anymore unforseen problems. I noticed I am leaking a small amount of hydrolic fluid from my clutch :roll: . I think its managable, but worst case, I have extra fluid, and even a rebuilt kit for the slave cylinder should it come to that.
I cant wait to get into Colorado! Talk to you soon!
