Oil
#41 Unread post by Sev »
Sadly that won't clear a blocked idle jet. Because by the time you're at 1/4+ throttle there isn't anything even trying to flow through the idle circuit anymore. It's all headed through the mainjet past the needlejet. The carb needle controls how much gas gets into the engine. Once you hit 3/4 throttle or more it's all the mainjet that decides how much gas is going into the engine.
The pilot is the smallest jet, and thus the most likely to gum up. Sometimes you can just take the float bowl off the crab, and stick a small flathead screwdriver in there, and twist out the idle jet. Then you fill it up with carb cleaner (its just a little brass[not sure of metal] tube with threads on the outside} and blast it with compressed air. Don't launch the jet across the room.
This should knock the blockage out, then you reinstall it into the carb, check the float height, install the float bowl and start it up again.
scan
#42 Unread post by scan »
Yeah, I might have just been lucky. Mine was not mechanical, or scientific. Just lazy. And truth be told, my problem was not at idle, but dogging down when I tried to apply max throttle.
* 2003 Kawasaki ZRX1200R *
ofblong
Real Name: Ben
#43 Unread post by ofblong »
why not try seafoam instead of premium gas?????
96' Honda Shadow Deluxe VLX
#44 Unread post by Sev »
:P Because that contributes to crankshaft condensation? :P
whoops! hehe, sorry.
Ice
What oil type for 1985 suzuki GS550? bikes
#45 Unread post by Ice »
i have a 1985 Suzuki GS 550 EF and i need to know what would be the best engin oil to fill it with? i don't have a manual as of yet. any suggestions??? i'd like to stay away from synthetics if possible
-thx
mgdavis
#46 Unread post by mgdavis »
Ice: you want "New Topic", not "Post Reply"
'07 Suzuki V-Strom DL650
Molon Labe!!!
