dr_bar wrote:JC Viper wrote:Then check the capacitors on the motherboard to see if any of them are bulging.
I had an older computer with an EPOX MoBo, after several years of use it started to cr@p out all the time. All the caps were bulging and leaking. I called EPOX and they ended up re-capping the MoBo for about $20 US, cheapest fix I've ever had for a PC. That computer still works...
In the years 2000 - 2003 many motherboards had bad capacitors that contained really low quality electrolyte formula. Something about Chinese/ Taiwanese manufacturers stealing the recipe and Japan got wise about it and left out a few components and the Chinese/ Taiwanese copied an incomplete formula.
Then there's the other explanation of heat causing the cap to bulge...
I still have an HP Pavilion from the 1999 era with an old Slot 1 Pentium III and it still runs with no manufacturing faults present. Ahh the days when HP made quality computers and still had tech support in Texas (I called tech support in 2000 and got a guy with an accent fitting of a Texas prison guard).
