See Shorts ride
Shorts
#541 Unread post by Shorts »
Shorts
When Seconds Count
#542 Unread post by Shorts »
Shorts
#543 Unread post by Shorts »
Shorts
#544 Unread post by Shorts »
jstark47
#545 Unread post by jstark47 »
OK, now I have a dumb question, but I don't know the answer so here goes: what's the difference between brake fluid and hydraulic fluid? The system is running both cylinders from one reservoir, right? So you've got one kind of fluid in the whole system. I guess that works (or you wouldn't be posting this) but I realize I don't know why it works. I assume there's a difference between the two kinds of fluid.... or is it just all labelling?
Skier
#546 Unread post by Skier »
Brake fluid is a hydraulic fluid.
The brake/clutch combo Shorts posted about has two master cylinders for two separate systems. Shredding a clutch line doesn't mean your brakes go out and having your brake fluid leak out doesn't make your clutch stop working.
Shorts
#547 Unread post by Shorts »
Shorts
#548 Unread post by Shorts »
Shorts
#549 Unread post by Shorts »
Shorts
#550 Unread post by Shorts »
