UPDATE: I drive a 2003 Shadow Spirit. It was jetted by Dyna Jet and has cobra pipes. I ride single, weigh 185 lbs, have a windshield and medium-sized bags on the bike.
I filled up and drove a total of 99 miles before my tank went dry (including the reserve). It's a 3.6 gal tank. Everything I can find says I should get 36-42mpg. Even on the low end, I should be able to get 130 miles before running dry. I'm getting closer to 26mpg!
If I ride only in the city, I get about 120 miles before having to switch to reserve. On the highway, I typically have to switch to the reserve as low as 56 miles into a tank of gas. Shouldn't I get better mileage on the highway? I am getting as much as 50 miles less on the highway than in the city, which doesn't make sense to me.
This bike only has 2,200 miles on it, so I can't understand why it's not getting better performance.
I found that I am getting 51+ MPG on the highway . I be happy with that .
Kind regards, Wizzard
My tank holds 5.8 US gallons and got 53mpg in period tests. I routinely do better, sometimes on a real easy day as high as 60, but usually about 55. I do not baby it, generally. Occasional 100+mph passes, cruising 70-ish. I don't know why newer bikes can't do that, too.
John
"83 XJ900RK
I easily get 55mpg, and have seen a best of around 60-65mpg. My range on a normal tank (not on reserve) is about 200 miles with around 2 gallons of reserve left.
I get 270 Kms per 19 lt, so thats 14.2 Kms per lt or 11.1 lt per hundred at R5.20 per lt x 19 lt thats R98.80 converted to dollars at R6.70 to Dollar 1 equals 14 dollars 75 cents to fill my tank. Am I paying too much?
My 750 gets 40 mpg in town. That's 160 miles (4 gals) to reserve. It can get 45 mpg in the city, but I have a bad habit of riding like my hair's on fire. Out on the highway it gets 48 mph at an average of 85 mph (192 miles to reserve).
Hayabusa averages in the low 40mpg range. If it's all highway and I keep it at about 80, I can edge out 50 mpg.
Ninja 250 gets 75mpg, I couldn't believe it. It may be because my wife is riding it and still learning, so the riding is all back roads with very little speeding.
[url=http://triphog.com]My name is Kevin, and I'm a triphog.[/url]
