This is probably the dumbest question ever but..
xk
#61 Unread post by xk »
I can relate Yngvai.
Had the same problems too but at least I got used to the instructor's bike FZ (at least on flat ground, on the incline it's another story)
The kicker is I'll have to re-learn it on my own bike as all bikes have different FZ's
Speed never killed anyone. It's suddenly becoming stationary that gets you. -- Jeremy Clarkson
Yngvai X
#62 Unread post by Yngvai X »
ok so i JUST came in from testing the friction point, and as someone said a few post's ago he said something about letting the clutch out slowly and it will move on its own. yeah i figured that out, to bad i never knew about that before all this.. but anyways so now that i found how to do the friction point and everything.. do i just want to not give it any throttle say if im at a light? just do the friction zone thing and let it start off slow THEN add throttle to get up to speed and shifting, ect. ect?
Jamers!
Real Name: James
#63 Unread post by Jamers! »
ZooTech wrote:
The Crimson Rider® wrote:are you trying to do launches?
Don't make me send you an e-smack, Verm... :roll:
You're the only one here concerned with "launching" your bike anywhere.
+1. the guys a new rider asking about getting going, why would he be launching his bike?
JWF
ATGATT
Sev wrote:What's a bike?
JWF
Shiv
#64 Unread post by Shiv »
That would work, yes. Eventually you'll be doing the two simultaneously.
All the friction point is where the collar and the drive gear starts to mesh together. This is when its getting the very minimum part of the available power from the engine. The gear is rotating based on the friction with the gear and is probably not even meshed up correctly at this point. Which is why it's called the friction zone.
If you let out the clutch without hitting the throttle, then the engine won't have enough RPMs to keep up and will choke and die. So when you get to the friction zone, apply a bit of throttle, let the clutch out slowly, and you're on your way.
A lot to think about at first, which is why God invented parking lots.
Have fun on the open /¦\
www.totalmotorcycle.com
I know, I was surprised too.
Yngvai X
#65 Unread post by Yngvai X »
thats what i thought, but if i let it out slowly it gets enough to go forward at like 2 grand and just moves without me even touching the throttle..
Andrew
#66 Unread post by Andrew »
I agree with Shiv, but you can start the roll without any throttle applied. If you release the clutch entirely with no throttle, of course you'll stall, but it shouldn't take much to keep it rolling.
2004 BMW K1200RS
[img]http://www.bmwlt.com/forums/images/smilies/BMWsmile.gif[/img]
Yngvai X
#67 Unread post by Yngvai X »
well my bike idols at around 1500.. so maybe thats why its proceeding forward with no throttle? i mean i have to let it out pretty slowly for it to do this but.. i dono it seems fine with me cause once i can predict it like everyone said, i can just hit that FZ point and give it throttle and take off.. right?
Yngvai X
#68 Unread post by Yngvai X »
well i want to go practice this right now, but unfortunetly its raining.
Rain is satan. :evil:
Kal
Real Name: Jade
#69 Unread post by Kal »
Everywhere was clsoed today and I couldn't get a new set fo HT leads and caps to replace the ones stolen last night. <sulk>
Right where was I?
Yes. Smoothness. Aim, for smootness if it feels smooth and steady then you are problably doing something right. If it is pitching around and is jerky then you probaly arent riding as well as you could be.
Try riding in the same style that you would drive a limo.
Kal...
Relationship Squid...
GPZ500S, CB250N, GB250Clubman
Yngvai X
#70 Unread post by Yngvai X »
Driving a limo?
