Slick suprise??
Posted: Sun Mar 26, 2006 8:43 pm
by swatter555
I was cleaning the rear tire rim with WD-40 to break up the grease, but I ended up getting some on the tire treads. The tire wasnt drowning in WD-40 or anything, but Im still a little concerned because I dont want any nasty suprises when I lean the bike over. I wiped it off with a rag of course. Am I safe?
Posted: Mon Mar 27, 2006 4:26 am
by Sev
Not sure, but I'd use soap and water from now on.... and take some of the same to whatever got hit with the WD40.
Re: Slick suprise??
Posted: Mon Mar 27, 2006 5:21 am
by runsilent
swatter555 wrote:I was cleaning the rear tire rim with WD-40 to break up the grease, but I ended up getting some on the tire treads. The tire wasnt drowning in WD-40 or anything, but Im still a little concerned because I dont want any nasty suprises when I lean the bike over. I wiped it off with a rag of course. Am I safe?
I've used WD40 to clean chain lube off the rear tire for years, never had a problem. I spray it on the tire and wipe it off while it's still wet. Doubt if there is much of anything left behind.
However, it doesn't get done too often. I'm a firm believer that if it's nice enough out to clean the bike then it is nice enough to go ride it instead. :laughing: :laughing:
Re: Slick suprise??
Posted: Mon Mar 27, 2006 7:10 am
by sapaul
Now that's an attitude I like :laughing: :laughing: :laughing:
Posted: Mon Mar 27, 2006 8:23 am
by swatter555
Thanks for the info.
