'90 EX500 2nd gear issue. Need assistance.
StangMATA50L
#1 Unread post by StangMATA50L »
Yesterday I was out and my chain snapped while in second and wadded itself around the front sprocket, killing the engine.
After fixing it, second gear is making a bit of a racket. It "clunks" at the same speed as the rear wheel is moving. i.e, the faster I go, the more rapidly it "clunks".
I'm assuming that the 2nd output gear is probably missing a tooth.
Is there potentially something else that I am missing?
Does the case DEFINATLEY need to be split for this one (so far it looks definate).
A parts Fische can be seen here:
http://www.kawasaki.com/Default.asp?str ... intParts=1
-IAN-
US Air Force
'90 EX500
#2 Unread post by BuzZz »
That's a Bummer, Dude. You most likey bent/broke something, ussually do when you wad the chain up around the countershaft sprocket. Your lucky if you didn't break the case, but a bent shaft or mangled gear is also possible, all of witch means opening the motor right up.
StangMATA50L
#3 Unread post by StangMATA50L »
BuzZz wrote:That's a Bummer, Dude. You most likey bent/broke something, ussually do when you wad the chain up around the countershaft sprocket. Your lucky if you didn't break the case, but a bent shaft or mangled gear is also possible, all of witch means opening the motor right up.
:frusty: :frusty: :frusty:
Thanks for the reply, Buzz. Just a crap situation...chain only had about 100 miles on it too.
Anyone wanna buy a 90 EX500 with a funny 2nd gear? :mrgreen:
-IAN-
US Air Force
'90 EX500
