Checking and Cleaning the petcock
Posted: Mon Apr 10, 2006 1:42 pm
Hello,
I'm getting my '85 virago 700 running again and have done more than a few things so far. It's running now but...
I'm having a problem with the petcock (vacuum operated) in the 'on' position. One minute, it works, and the next minute it doesn't. Here are my questions;
1)My fuel lines are laying over the middle of the carbs. This means that the fuel has to travel "uphill" a little to get to the carbs. Now, the fuel can get there OK on 'pri', but does anyone think that fuel would have a problem getting 'up' the line with the petcock in the 'on' position while only getting a shot of gas during every ignition stroke?
2)If you have a vacuum operated petcock, is that where the fuel line is routed on your bike?
3)How do I check and clean my petcock? And are there any small bores I should worry about cleaning out?
Thanks!
Thanks!
