fuel wont flow into the carb
jmillheiser
Legendary 2500
Legendary 2500
#1 Unread post by jmillheiser »
the bike is a 2001 buell blast. the problem is that fuel will not flow into the carb unless the bike is tilted way to the right. I checked the needle and seat on the carb and they are fine.
the carb is uphill from the petcock so gas wont flow. its a gravity feed petcock so there is no vacum line, just one line going from the petcock to the carb.
id swear this bike was designed by monkeys
niterider
#2 Unread post by niterider »
I hope by now you have fixed the problem. Since the fuel line is up hill do you have enough fuel in the tank???
1993 750 Vulcan
one seater
ear shave, pod filters
rear turn signal relocation
lowered rear 2" soft tail
horn relocation
