Not A Troublemaker
MotoF150
Not A Troublemaker
#1 Unread post by MotoF150 »
Hello to everybody new to this forum. I got thrown off of The Suzuki Forums cause I was the only person that cut down the Suzuki bike I owned. I am very honest and I cut down the bike I own to help and protect new people from not making the same mistake I did and buying the same bike I own. I understand most people have pride and they are going to say the bike they own is the best, but I know most people are not telling everybody everything, the problems they have, and short commings of the bike. I understand that. I promice I will be good and respectfull to everybody. Thank You
#2 Unread post by High_Side »
Welcome to the TMW. What kind of trouble did you have with the M50?
MotoF150
#3 Unread post by MotoF150 »
Dear Mr High_Side, Thank you for the welcome, the problems I have with my M50 is the black exhaust smoke, backfires, and blown ign fuses and I was told its normal and it can't be fixed I do know one other owner with the same exact problems. Warranty and the extended warranty don't cover problems that are considered normal by the dealer. Case closed.
Loonette
Real Name: Kristin
Years Riding: 13
#4 Unread post by Loonette »
Welcome aboard!
Did you try documenting every little detail (including your conversations with the dealer) and submitting a formal complaint to Suzuki? Also, most states have lemon laws - even for motorcycles. I thought I was going to have to use the lemon law to get a remedy for my Meanstreak last year, but before it came to that my bike finally blew the head gasket that had been only a bit leaky beforehand. Anyway, good luck - I hope something works out for you.
Enjoy the forums (and try to behave :wink: ).
Cheers,
Loonette
2006 Mean Streak 1600
MotoF150
#5 Unread post by MotoF150 »
I never thought of the lemon law for motorcycles, the problem I may come up with is the problem I have may be considered normal. I was told its normal for all V Twin engines to backfire.
jstark47
#6 Unread post by jstark47 »
MotoF150 wrote:I was told its normal for all V Twin engines to backfire.
Someone's BS'ing you. We have an '04 Marauder, essentially the same engine. It doesn't backfire, no black smoke, runs fine.
Welcome to the forum.
Jthmeffy
#7 Unread post by Jthmeffy »
um, yah, u need to nip that right in the "procreating" bud, there is NO way that's normal.. get ahold of Suzuki ASAP
EDIT:: hahaha, i love the filter on this forum
camthepyro
#8 Unread post by camthepyro »
Welcome!
My nighthawk backfires a little, but it's a parallel twin, and it's 24 years old. But I wouldn't think it'd be normal for a bike to back fire if it's in it's optimal running condition.
Member of DWPOMD and RATUBBAW
'80 Suzuki GS 450
MotoF150
#9 Unread post by MotoF150 »
I know its not normal, there's nothing I can do when any dealer refuses to repair it, I can't twist his arm and make him, dealers have total authority on warranty, I called Suzuki they say there is nothing they can do, dealers have total authority on warranty. If you take your bike in for a warranty problem and if the dealer feels its not a problem its a normal condition, the dealer can bill you his normal labor rate for looking at it.
Wizzard
#10 Unread post by Wizzard »
1st off , welcome to the TMW Forums .
My spousette and I both have Suzuki cruisers . Her's is a 2000 Maurader and mine is a 96 Intruder .
She had a back firing problem because the previous owner installed custom pipes without rejetting . Mine has never backfired with the exception of when I had an electical short which I fixed .
Regards, Wizzard
