1984 honda shadow vt700cc
BROKENHEARTED2099
#1 Unread post by BROKENHEARTED2099 »
the problem that im having is that i changed out the diaframs on the carbs and now the bike idles real good but when i go to throtle up it bogs down and dies i just dont konw why :frusty:
#2 Unread post by BuzZz »
The bike bogs when you open the throttle, like it's getting too much gas? I'm assumeing...?
Did you change the needles with the diaphrams? or replace the old ones with the clips in a different position?(if your's have adjustable needles). If so, then the changes made the mainjet become/act larger than before.
But that's just my guess anyways.... :wink:
CORSCO
#3 Unread post by CORSCO »
Check to make sure you did not pinch the diaphrams and they are in the correct position. Did you put the diaphram spring back in?
