Page 1 of 2
bike wont start help plz
Posted: Wed Apr 19, 2006 10:30 pm
by jordysean
2 days ago i tried to start my bike up and she started up then she just died b4 i had chance to rev it now it wont start i am going to get a spark plug spanner to see if the spark plug is dead, any other suggestions of what it could be also when i try to start her the headlight will light up 4 a second if the switch is on but usually the headlight will only turn on if the engine is running and yes i have a full tank of petroll it was running fine until 2 days ago
Posted: Wed Apr 19, 2006 11:36 pm
by DivideOverflow
What type of bike?
Posted: Wed Apr 19, 2006 11:52 pm
by jordysean
honda melody 1983 ns50
Posted: Thu Apr 20, 2006 4:08 am
by -Holiday
i'd help you, but Im out of breath from reading the longest run on sentence in human history.
Posted: Thu Apr 20, 2006 9:45 am
by skinnyjoint
-Holiday wrote:i'd help you, but Im out of breath from reading the longest run on sentence in human history.
hahaha
Posted: Thu Apr 20, 2006 9:57 am
by camthepyro
Is the battery good? Just because the headlight lights up, doesn't mean you have enough charge to start the bike. Is the bike in gear? Most bikes won't start unless they're in neutral or have the clutch pulled in. This is going to sound stupid, but is the petcock in the "off" position?
Posted: Thu Apr 20, 2006 10:04 am
by BubbaGump
camthepyro wrote:Is the battery good? Just because the headlight lights up, doesn't mean you have enough charge to start the bike. Is the bike in gear? Most bikes won't start unless they're in neutral or have the clutch pulled in. This is going to sound stupid, but is the petcock in the "off" position?
Good points!
Actually, I just like you saying petcock!
These are probably the top 3 problems for a non-start. Beyond that it usually gets harder to diagnose and more costly to fix. Spark plug's are a good idea to replace...air filter, fuel lines. With a bike that old is there a chance of rust in the tank plugging your fuel lines? I've seen that before on older bikes.
Posted: Thu Apr 20, 2006 10:12 am
by jordysean
it doesnt have gears it is a moped and i have been trying to start it using the kick start because the battery is now flat after trying to start by pushing the button, fuel is getting to the carb so i think that it will just need a new spark plug hopefully ill get a new spark plug tomorow and see what happens
Posted: Thu Apr 20, 2006 10:24 am
by BubbaGump
jordysean wrote:it doesnt have gears it is a moped and i have been trying to start it using the kick start because the battery is now flat after trying to start by pushing the button, fuel is getting to the carb so i think that it will just need a new spark plug hopefully ill get a new spark plug tomorow and see what happens
Might just need to clean the one you got w. a wire brush. Carbon buildup will result in poor spark.
A bit of sandpaper works too.
Posted: Thu Apr 20, 2006 10:28 am
by camthepyro
Well, I'm not familiar with kick start bikes, but if the battery is dead, how are the spark plugs going to fire?
