Page 1 of 3
please explain x-siding
Posted: Tue Apr 25, 2006 8:38 am
by Dirtytoes
okay, can someone explain to me all the siding stuff? lowsiding, highsiding, side siding?
i've always been confused about them.
P.S. really off topic but am i supposed to pour water anywhere into the ex500? .....i.e. in a car, you have to pour water into the carborator....is it the same for the ex?
Posted: Tue Apr 25, 2006 8:43 am
by Unnamed
Think about taking a tight corner... you lean over to the side...
If your tires lose traction and the you fall off of the side closer to the ground, its a lowside.
If your front tire gets going at a different angle or moves at a significantly different speed from the rear and you get catapaulted over the side of the bike further from the ground, its a highside. As you may imagine, these will be a little more painful.
Posted: Tue Apr 25, 2006 8:44 am
by skoebl
Uhm....I wouldn't put water in the carb at all....Wouldn't that, like, ruin stuff? :|
Posted: Tue Apr 25, 2006 8:46 am
by Unnamed
skoebl wrote:Uhm....I wouldn't put water in the carb at all....Wouldn't that, like, ruin stuff? :|
Wrong thread I think :laughing:
Posted: Tue Apr 25, 2006 8:50 am
by dieziege
Pour water into the carb? Ummm how much? Are we talking a 2L car needs two liters of water or what? Do you need to turn the engine over by hand as you add water?
Anyway, I think the answer is no. Motorcycles have built-in rain collectors to keep the electrical and fuel systems properly hydrated.
P.S. Low side is when you tip the bike over at speed and fall off behind letting the bike slide ahead of you. High side is when you fall off ahead and let the bike follow behind. Both are generally undesirable, though low siding is considered slightly less impressive if you are making videos.
Posted: Tue Apr 25, 2006 8:52 am
by Pongo
:lol:
At last! The answer to high gas prices.
Re: please explain x-siding
Posted: Tue Apr 25, 2006 9:04 am
by flynrider
Dirtytoes wrote:P.S. really off topic but am i supposed to pour water anywhere into the ex500? .....i.e. in a car, you have to pour water into the carborator....is it the same for the ex?
Are you nuts?? :o
Posted: Tue Apr 25, 2006 9:06 am
by SuperRookie
Sounds like someone needs a refresher in 'engine basics'
Posted: Tue Apr 25, 2006 9:15 am
by Jamers!
the video im posting is a high side, a very extreme high side but a highside none the less. http://www.roadracing.org/media/hshs.html
did you see the way the back wheel lost traction, regained it and launched him off the bike? that is a high side.
JWF
Posted: Tue Apr 25, 2006 9:19 am
by camthepyro
Water (even a drop) = bad for fuel systems
You don't want any water at all getting into your fuel system at all. So like, if some water gets poored into your gas tank for some reason, you have to empty your gas tank, so the water doesn't get in the fuel system. I can't exactly remember why, but it has something to do with damage to the system.
