Quick chain tension question
Posted: Thu Apr 27, 2006 7:51 am
Hi all, I have an '86 Kawasaki Ninja 600R, and I was just wondering if I should be tensioning the chain - the vertical travel on the lower run is within the proper range, but the top run seems to be touching the swingarm (well the chain pad on the swingarm anyway).
Should I leave it be or maybe try and lift the top run off the swingarm by increasing the tension (maybe beyond spec)? Thanks as always for any input!
Doug
Doug
