Starter.
Posted: Tue May 09, 2006 9:48 am
by NorthernPete
So, I have been working on my 83 Maxim 650 today. I got the battery hooked in and attempted the starter switch (just to see if the starter will work) and all I get is a click from what I believe is the starter cylanoid (a little round device that is hooked between the battery and the starter motor) just a click, no turning over. I think the cylanoid is shot, am I right?
Posted: Tue May 09, 2006 9:50 am
by CORSCO
If you hear a click from the sylanoid, that means it is doing its job. Sounds like the battery is low. IF the battery is good, you may have starter motor issues. But check that battery first.
Posted: Thu May 18, 2006 2:44 am
by NorthernPete
battery seems good BTW, all lights are bright and the horn is strong.... But I'll try swapping it out with my new battery and see what happens.
Posted: Thu May 18, 2006 3:37 am
by TechTMW
Hiya Pete, starters are the biggest comsumers of electricity on your bike. Most require OVER 12 volts to spin up. Your lights and whatnot will still light up even when the battery is low on volts.
Posted: Thu May 18, 2006 5:44 am
by NorthernPete
I changed the battery out, still the same thing, so I took off the starter cylanoid, brought it to a starter shop, they tested it, and pronounced it dead...so one new cylanoid later, I now have the starter motor turning over...w00t.
Posted: Thu May 18, 2006 8:24 am
by CORSCO
Great, a missed diagnosis on my part! :x
Posted: Thu May 18, 2006 8:27 am
by NorthernPete
Corsco, Pretty much any advice you have given has been spot on, not bad considering you cant see what the problem is and are relying on people describing a "doohicky on the thingamabob that aint workin"
I for one am glad to have you to ask for advice!
