Battery charge
Bolo
Battery charge
#1 Unread post by Bolo »
Hi, a question. I need to recharge my battery, can I do it with the battery mounted on the bike is a honda cbr 600 f4i?
Myself002
#2 Unread post by Myself002 »
welcome to the foums and I would direct this question to either new bikers or maintanince.
WheelieGrip
#3 Unread post by WheelieGrip »
I'm pretty sure you need a battery charger and your going to have to take it off i beleive.... and place it on a shelf or something.. if its on the ground it like drains ur battery out faster or something...
vroooom
niterider
#4 Unread post by niterider »
You can charge it on the bike, but you need a charger that will put out a small current like maybe 2 amp charge.It is best to have your ignition shut off. Be sure your water level in battery is up to level.
1993 750 Vulcan
one seater
ear shave, pod filters
rear turn signal relocation
lowered rear 2" soft tail
horn relocation
Wizzard
#5 Unread post by Wizzard »
Yes , you can charge it while it is still in the bike .
Welcome to the TMW Forums .
Regards, Wizzard
bok
#6 Unread post by bok »
welcome...there are even some chargers out there that you can permanently affix to the battery so you can just hook up the "trickle" charger with a quick connect.
Bx RedBull
Re: Battery charge
#7 Unread post by Bx RedBull »
Bolo wrote:Hi, a question. I need to recharge my battery, can I do it with the battery mounted on the bike is a honda cbr 600 f4i?
First off, right on with the bike selection. There is only one choice.
Secondly, I agree with everyone else. I purchased my '02 F4i and had to charge the battery and was easily able to do so with the battery still attached and inside the bike.
Good luck and always RIDE RED :motorcycle: :motorcycle3: :motorbike: :spot: :devil2: :devil: :littlebike2:
[b]"Do not go where the path leads you...Go where there is no path and leave a trail."[/b]
[img]http://img9.picsplace.to/img9/13/Rage.JPG[/img]
Keyoke
Years Riding: 22
#8 Unread post by Keyoke »
Yup, as everybody else has said, you can charge the battery while it's still mounted in the bike, however I would reccomend disconnecting one of the cables first... (just been a habit of mine for a while!)
Don't give up.
Eunic
#9 Unread post by Eunic »
I don't want to make this sound like an endorsment, but I have used a "Battery Tender Junior" for years. Like someone said here earlier, a connector is attached to the battery and all you have to do is plug in the charger when your not going to be using the bike for awhile. DONT use a automobile charger. To be brief, to much current.
Eunic
An American Eunuch
SleepyHeadTT
#10 Unread post by SleepyHeadTT »
I also use a quick disconnect that can be routed outside of the battery box and out under the seat. It gets retracted back under the seat during the riding season.
I am a bit concerned with your situation, You shouldn't need to charge the battery throughout the season if you ride at least once a week. I ride everyday for about 50 miles at a time. Riding this far gives the alternator more than enough time to full supply the batt with enough amps and volts to keep it topped off.
If you are running out of juice, I would highly recommend one of the other members suggestion and ensure your water (distilled) levels are full in the battery.
Another good suggestion is take the moto to AutoZone. AutoZone? Yes, AutoZone. They will test your battery for free, to include water density testing. They can tell you whether or not your battery have had it.
Just a suggestion...
