Can't breathe
Posted: Sun May 21, 2006 11:28 am
by snwbrdr
more air=more bang=morepower. right, so if i could increase air flow then i could potentially increase power. so on myninja 250 im thinking about having my dad fabricating somekind of forward facing air scoop. i know it'll only increase power at speed, but does anyone wanna say something against thisbefore i do it? i know it wont make much of a difference, but im bored and need something to do, plus itll be cool and a turbo would be really difficult.
Posted: Sun May 21, 2006 11:34 am
by Mintbread
Please don't do that.
More air is good but it must be balanced with more fuel and a free flowing exhaust. You will simply lean your engine to the point of starvation, making it go even slower.
Posted: Sun May 21, 2006 11:57 am
by BubbaGump
Mintbread wrote:Please don't do that.
Mint is dead on. More air only makes you go faster when you have more fuel and your air/fuel ratio is correct. Making simple mods wont improve anything. Something as simple as going from stock exhaust to straight pipes on a bike can affect performance if the carbs aren't re-jetted.
Posted: Sun May 21, 2006 1:51 pm
by flynrider
The amount of ram air pressure you'd get with forward-facing airscoops wouldn't even be noticed by your bike. It doesn't move fast enough to create a ram effect.
If you want to move more air through the engine, you need a free-flowing intake path, carb mods to deal with the increased airflow and a pipe that will reduce back pressure. Even after you spend a fortune on all that stuff, you'll only be looking at a gain of a few hp on the top end. You probably wouldn't even notice it.
Posted: Mon May 22, 2006 1:15 pm
by snwbrdr
I had the things you guys mentioned in the back of my mind. i thought i would need to do all that, and i thought i wouldnt notice the difference. thanks anyway.
