Page 1 of 4
Dry your bike off after washing
Posted: Sun May 28, 2006 7:05 pm
by Scoutmedic
I got this cool tip the other day from a relative. If you have a shopvac with the blower outlet and a reducer attachment, clear the line then use it to blow dry the bike after you've washed it. I tried this today and it worked really well. No water spots and, I didn't have to hand dry it. Not sure if this has ever been mentioned here but, thought it might be worth passing on.
Posted: Sun May 28, 2006 7:32 pm
by BuzZz
W-a-s-h ??? the bike?
What means these words? Me no hear before.
D-r-y ??? Strangerest and strangerest words and ideas......
Wack the windshield on the way by and see how many bugs fall off..... that's close enough, right?
Posted: Sun May 28, 2006 11:41 pm
by NorthernPete
My bug guts keep the thing together....
Re: Dry your bike off after washing
Posted: Mon May 29, 2006 12:01 am
by Mintbread
Scoutmedic wrote:I got this cool tip the other day from a relative. If you have a shopvac with the blower outlet and a reducer attachment, clear the line then use it to blow dry the bike after you've washed it. I tried this today and it worked really well. No water spots and, I didn't have to hand dry it. Not sure if this has ever been mentioned here but, thought it might be worth passing on.
I have found that compressed air manages to force water where it would, under normal operating conditions, not be able to go.
Posted: Mon May 29, 2006 12:03 am
by NorthernPete
Shammies work wonders....
Posted: Mon May 29, 2006 3:41 am
by Scoutmedic
at Buzz and Pete! Even though mine is new, it's a sad reality that my bike's been dirty pretty often. Been riding in the rain a lot and I don't feel like washing it in the rain or after a long shift at work.
Mintbread, very true and a valid concern I hadn't thought of until you reminded me of it.
I had planned on picking up a new chamois. Guess I should still grab one or two.
Posted: Mon May 29, 2006 9:26 am
by NorthernPete
Meh, rain is water...water washes....
Posted: Tue May 30, 2006 1:19 am
by canuckerjay
Mr. Clean auto dry also works well -- even more perfect for the masculine quest for absolute laziness
Posted: Tue May 30, 2006 1:26 am
by Scoutmedic
I just looked at those last night. How many washes do you get out that before you need a refill?
Posted: Sun Jun 04, 2006 11:37 am
by VermilionX
i have the auto dry... but i haven't used it for a long time.
anyway... there's an indicator on it to tell you when you need to replace the filter.
also... since you'll be using it on a bike, you should get more uses out of it.
i can't remember how many uses it can do before you need to replace the filter and re-fill the soap but im it's not more than 10 uses. but that's for a car, bike should get way more uses from it.
