Page 1 of 2
wow! just... wow!
Posted: Thu Jun 08, 2006 5:16 pm
by VermilionX
Posted: Thu Jun 08, 2006 5:18 pm
by TheImp
SOMEONE SPILLED COOLANT ALL OVER THEIR BIKE AND FORGOT TO WIPE IT OFF.
BTW, are those woofers I see all over the fairings? o_O
EDIT: And on closer inspection a plexiglass chamber for bass...
No need for a horn, just blast anything on that bike when needed.
Posted: Thu Jun 08, 2006 5:19 pm
by VermilionX
yeah, and i thought you totally missed the point.
Posted: Thu Jun 08, 2006 5:20 pm
by Ninja Geoff
HAHAHAHAHAHAHAHA that's awsome
Posted: Thu Jun 08, 2006 6:32 pm
by Shiv
And who says you can't listen to music without headphones...
Posted: Thu Jun 08, 2006 7:53 pm
by Dima
I like how there is an amp on the bottom of the bike. Bike probably weights extra 100 pounds.
Posted: Thu Jun 08, 2006 11:08 pm
by Keyoke
I saw this in MCN - its had about £10,000 GBP worth of extras, the amp alone was £6000. There's even a guitar jack in the exhaust so you can play gigs!!
Onoy problem is, it doesnt go - the amp takes up the entire insides of the fairing, so the engine has been removed.
Still kinda groovy, though...
Posted: Fri Jun 09, 2006 12:12 am
by BigChickenStrips
cool pic. note the gas cap is accually a 12" subwoofer. kinda ghey if theres no motor though.
Posted: Fri Jun 09, 2006 2:43 am
by Dichotomous
100 lbs... ha, each of those speakers is about 2 lbs, and that sub is likely 20-50 alone, then the 10-30lbs amps, along with all the wiring. That thing is heavy, good thing it doesnt have a motor, wouldnt do much anyways. Wonder how many speakers you could really get on a sport bike fuctionally anyways though
Posted: Fri Jun 09, 2006 3:09 am
by mysta2
so is the throttle the volume? you could just play motorcycle sounds while you watch Faster with your' "O Ring" (that is an LCD in the seat right)... I guess that's where your' head would have to be if you were the one that built or bought that "bike"
