1981 honda master cyllinder
Posted: Fri Jun 16, 2006 6:36 am
by honda750
I have a 1981 honda cb750c that I'm having problems with the brakes on. I rebuilt the callipers and cleaned it out to the point that I can squeeze the piston in by hand when there is no fluid in. The problem isnt down there, I'm pretty sure. The issue I'm having is that when I opened up the master cyllinder, I took out the two bolts and then was unable to get the reservoir off. I am confused as to what I can do to take that off and make sure that the fluid is being pulled back, bringing out the brakes. Right now, when I put fluid in the system, the brakes lock after squeexing the lever a couple times and can only turn the wheel with all my strength. Te bearings in the wheel are good and the callipers are good, so here's the question. What can I do to get the reservoir off and then clean out the system?
nik
(here is where you can get a complete diagram of the master cyllinder)
http://houseofmotorcycles.bikebandit.co ... CB750C.asp
Alcohol Rehab
Posted: Fri Jun 16, 2006 9:53 am
by TechTMW
Unless I'm misunderstanding you, I think you have a normal condition. Brakes don't have return springs or anything like that. The force of the Disk against the pad is what pushes the caliper out (and thus returns the fluid to the reservoir)
Have you tried rolling the bike forward and braking and then releasing? Seems like all you've done is tried to turn it by hand. With new components and pads, it may be tight for the first few times you ride it.
Posted: Fri Jun 16, 2006 1:11 pm
by 9000white
did you clean the slider pins when you rebuilt caliper??
Posted: Fri Jun 16, 2006 1:17 pm
by CORSCO
If the brakes are locking up after a few uses, the bleed hole in the master cylinder is blocked. There should be a small hole after the piston assy. in the master cylinder. Make sure it is not clogged. The fluid is not able to return through this hole and it keeps pressure on the caliper pistons.
I have never tried to remove that portion of the master cylinder before. From the diagram, I guess it can come apart. Try SLIGHTLY tapping it with a dead-blow hammer to release it from the O-ring. Be very gentle and never force anything.
master cyllinder
Posted: Sun Jun 18, 2006 4:25 am
by honda750
dr. bob,
i cleaned both the main slider bolts for the calliper and the slider pins for the brake pads.
i dont think that is holding us up at all..
I still have a problem and can't get the reservoir off to get the cyllinder out and clean it.
i'm stuck
Health discussion
