IT'S HERE! it's finally here! - Total Motorcycle Community Forums
Skip to content
Advanced search
  • Quick links
    • Unanswered topics
    • Active topics
    • Search
  • FAQ
  • Login
  • Register
  • Search
  • Unanswered topics
  • Active topics
  • Print view
Advanced search
  • 1
  • 2
  • 3
  • 4
  • 5
  • 6
  • Next
VermilionX
  • Quote
#1 Post by VermilionX » Tue Jun 20, 2006 5:42 pm
i'll install it tomorrow and post how much difference it makes.
-Holiday
Re: IT'S HERE! it's finally here!
  • Quote
#2 Post by -Holiday » Tue Jun 20, 2006 5:43 pm
VermilionX wrote:post how much difference it makes.
how will you know?
2000 Suzuki Bandit 1200s
Vespa Rally 200 in pieces
VermilionX
  • Quote
#3 Post by VermilionX » Tue Jun 20, 2006 5:46 pm
-Holiday wrote: how will you know?
well im pretty sure the performance difference will be more noticeable than the SET valve mod i did.
w/ the limiter off, im sure the difference will be very noticeable.
Shorts
  • Quote
#4 Post by Shorts » Tue Jun 20, 2006 5:52 pm
Before you install it, go get the bike dynoed for baseline. Install that and dyno again.
Many times improvements are minute, much of the "improvements" are all in your head..."well I installed it, yeah, it feels faster".
biff
My Motorcycle: yeah sure
  • Quote
#5 Post by biff » Tue Jun 20, 2006 5:53 pm
What is that Verm?
Honda, Harley , Kawasaki. Two wheels are two wheels...watch out for your fellow riders.
Jamers!
Real Name: James
  • Quote
#6 Post by Jamers! » Tue Jun 20, 2006 5:53 pm
VermilionX wrote:[
the speed limiter or the rev limiter?
JWF
ATGATT
Sev wrote:What's a bike?
JWF
VermilionX
  • Quote
#7 Post by VermilionX » Tue Jun 20, 2006 5:56 pm
JWF
the TRE bypasses the ECU's fuel injection limiter on 1st-4th gears and bypasses the top speed limiter.
it has nothing to do w/ the rev limiter.
i have a 750 now so the top speed limiter isn't even an issue. i don't think a 750 can go 186mph w/o some serious mods.
jmillheiser
  • Quote
#8 Post by jmillheiser » Tue Jun 20, 2006 5:59 pm
only thing the 750 would need to go 186mph is new sprockets and the speed limiter removed.
Aya Mk I could probably have broken 200 with a sprocket change
VermilionX
  • Quote
#9 Post by VermilionX » Tue Jun 20, 2006 6:03 pm
jmillheiser wrote:only thing the 750 would need to go 186mph is new sprockets and the speed limiter removed.
hmmm... interesting. no wonder guys at GDC are changing their sprockets and chains.
but anyway... i don't care too much for top speed at this point. i just wanna remove the limiter on 1st-4th gears right now.
VermilionX
  • Quote
#10 Post by VermilionX » Tue Jun 20, 2006 6:39 pm
Shorts wrote:Before you install it, go get the bike dynoed for baseline. Install that and dyno again.
im not sure how they do dyno test.
which gear to they test it? bec if it's for 5th or 6th gear... then the TRE won't make a diff on total horsepower.
besides like i said, im not installing the TRE for more peak hp. im installing it to get an instantaneous power response on 1st-4th gears.
  • Print view
  • 1
  • 2
  • 3
  • 4
  • 5
  • 6
  • Next
Jump to
  • ↳   Total Motorcycle Talk
  • News, Events and Stories
  • Reviews
  • Rider Cafe'
  • Off Topic!
  • Total Motorcycle General
  • Board index
  • All times are UTC-11:00
  • Delete cookies
  • Contact us
Privacy | Terms
