Page 1 of 2
how do you think this mod would affect my bike
Posted: Sat Jun 24, 2006 12:55 am
by deathlucky
i have a gs500f and its really sad when ur doin below 4k rmp i mainly ride around the city and have to stop at lights every 2 seconds what do you will think would happen if i did this
advance timing
K&N air and oil filters
jet kit
it was blowind oil out the air box the other day. would i use a heaver oil to help that like 15w-50? it was only leaking because i floged the dodo out of it. its stoped leaking now
Posted: Sat Jun 24, 2006 1:34 am
by Mintbread
Those mods will be of little benefit around town. I have a 1200 Bandit with a stage III jetkit K&N's and a 5 degree ignition advance and I lost some power down low and in the midrange but now have bucketloads up top.[/list]
Posted: Sat Jun 24, 2006 2:30 am
by deathlucky
really with the ignition advance i thouht you would get more down low i have to make the ignition my self so i can make it to any degree i like i was think 5
Posted: Sat Jun 24, 2006 2:53 am
by DivideOverflow
Can you try to make more coherent sentences? I have a very hard time understandng you.
Re: how do you think this mod would affect my bike
Posted: Sat Jun 24, 2006 5:35 am
by Lion_Lady
deathlucky wrote:i have a gs500f and its really sad when ur doin below 4k rmp i mainly ride around the city and have to stop at lights every 2 seconds
it was blowind oil out the air box the other day would i use a heaver oil to help that like 15w-50 but it was only leaking because i floged the "O Ring" end off it its stoped leaking
advance timing
jet kit
Umm, err, most bikes only "blow oil out the airbox" when you've OVERFILLED the oil.
P
Posted: Sat Jun 24, 2006 5:56 am
by Relsek
DivideOverflow wrote:Can you try to make more coherent sentences? I have a very hard time understandng you.
Careful now, the last time I made a comment like that I was called a racist. I'm not sure how they came up with that logic, but they somehow did.
Kevin
Posted: Sat Jun 24, 2006 11:11 am
by deathlucky
racist what do you have some thing againts australians? hahaha nah just kidding
it wasnt over filled cause by the time i got around to puttin more in it in was just below the low mark
Posted: Sat Jun 24, 2006 11:30 am
by Mintbread
The crankcase breather hose runs into the airbox so hot air, moisture and small amounts of oil end up in the airbox as well. There is usually a drain hose which exits the airbox to get rid of accumulated oil etc but if this is blocked the excess oil will just sit around inside.
deathlucky wrote:really with the ignition advance i thouht you would get more down low i have to make the ignition my self so i can make it to any degree i like i was think 5
The ignition advance makes a very small difference to the bikes performance. It improves throttle response slightly and just seems to smooth things out a bit.
Posted: Sat Jun 24, 2006 11:49 am
by deathlucky
yer it has all leaked out.
oil got splated all over my air filter.
would a heavy oil like 15-50 help stop this from happening?
Mintbread is that a really helmet in your pic hahaha its sweet
Posted: Sat Jun 24, 2006 1:59 pm
by Mintbread
Oil should not be forcibly ejected from the engine no matter what the weight.
Yeah, it is a real helmet. It is a Simpson Bandit with a custom paint job.
