Screeching coming from rear wheel.
buddhacide
#1 Unread post by buddhacide »
I was out practicing today. I came a stop and went to make a turn but ended up skidding the back tire a bit somehow. Anyway, as i was riding home I noticed there is now I high pitch "squeel" coming from the rear wheel area. This is there whether i'm driving or in neutral. How bad do you think this is?
Current: 2008 Vulcan 900 custom
Previous: 1999 V-star 650 custom
DivideOverflow
#2 Unread post by DivideOverflow »
replace your brake pads.
2008 BMW K1200S
2003 Z1000 - For Sale
2004 Hyosung GV250 - sold
Bachstrad37
#3 Unread post by Bachstrad37 »
How bad is this? Unless you smell something burning, problem is likely minor.
It can range anywhere between pads being too hard for the rotors to worn pads. Spray er' down with some brake cleaner and see if it helps. If it doesn't replace them with softer pads.
Note: your pads won't last as long going softer, but it'll quiet them a quite a bit.
2003 VN1500P Kawasaki Mean Streak
2009 Yamaha Nytro FX
flynrider
#4 Unread post by flynrider »
Bachstrad37 wrote:How bad is this? Unless you smell something burning, problem is likely minor.
Unless the squeal is coming from the wheel bearings. These can be checked when the rear wheel is off.
I wouldn't do a whole lot of riding on that bike until I determined where the squeal is coming from.
Bikin' John
'93 Honda CB750 Nighthawk
buddhacide
#5 Unread post by buddhacide »
I am so frustrated with this thing today. I have no place nearby to take the bike to get checked out, and I have almost nobody that can help me trouble shoot. I way too much of a beginner to be taking stuff apart and even if i could i dont know what to look for. Its not like i live in the sticks either I live in the city.
sharpmagna
#6 Unread post by sharpmagna »
Dude, your signature makes it seem like your hawking motorcycle manuals. Why don't you crack one open for you bike and see how to do it yourself :laughing:
If your bike has rear disc brakes, it is really easy to work on. If it is drum brakes, it is a bit harder but still doable for a novice. Especially a novice with a service manual... :roll:
1987 Honda <B>SUPER</B> Magna
buddhacide
#7 Unread post by buddhacide »
LOL - I just have a way to get them, I still dont know anything about bikes. Also the manual I have doesnt go into detail about stuff like this. I'm guessing the service manual is different then the owners manual. Maybe i'll try to track one down.
NorthernPete
Years Riding: 11
#8 Unread post by NorthernPete »
here ya go...have a looksee.[/url]
2009 GS500F
MotoF150
#9 Unread post by MotoF150 »
the first thing I would check is to make sure the axle nut didn't come loose, or maybe the wheel bearings are spinning on the outside, you can tell if its the brakes buy using the brake as ur moving and see if that increases or decreaces, or changes the noise. I use a bent nail instead of a cotter pin to hold my axle nut on.
MakeCarsStandSTill
#10 Unread post by MakeCarsStandSTill »
Prop it on a stand and rev it up and try to locate the noise
Live on the edge., Ride on the edge.
2006 Gsx-R1000(sold)
2006 Gsx-R750 (on its way)
