'83 v45 750 honda
Posted: Mon Jun 26, 2006 11:46 pm
by fordthunderz
With the engine NOT running the fuel pump pumps no fuel. According to the book it should pump 614 cc with the key in the on position and I assume this is with the engine NOT running?? Is this correct and the fuel pump needs to be replaced?
Thanks
JR
Posted: Tue Jun 27, 2006 10:34 am
by 9000white
will it crank and run now??? if it will disconnect the fuel line and put it in a container then crank it and let it run for 6 seconds then cut it off.multiply what fuel you get times 10.that will tell you how much it is pumping.i have a v30 magna and you have to jumper out the fuel pump to test it when not running.yours might be the same.
Posted: Tue Jun 27, 2006 11:19 am
by fordthunderz
the bike does run, so I will run my flow test like that. Thanks for clearing things up for me!!
JR
Posted: Tue Jun 27, 2006 1:34 pm
by fordthunderz
ok, I ran the flow test and came up with 1.25 oz which calculates to 12.50 per minute. The book calls for 22oz, I assume per minute + or - 10%. I checked all the hoses, cleaned the petcock and changed the filter, so the $110.00 question, bad fuel pump? The bike stalls after about a 7 to 10 mile ride and starts back up after an hour or more all at high speed 55 to 65 mph.
Any help is greatly appreciated!
Posted: Tue Jun 27, 2006 4:15 pm
by 9000white
make the fuel flow test with the fuel cap open--may be the vent stopped up.if you do need a pump there is one you can get for a car that will work .it is a bunch cheaper.it is one for a 1983 Honda Civic with a 1.3 liter engine.may have to adapt the wires but it will work.
Posted: Tue Jun 27, 2006 5:00 pm
by BuzZz
Re-test the pump with fuel cap open. You may be pulling against a vacuum.
Posted: Tue Jun 27, 2006 8:09 pm
by TechTMW
Yes ... vacuum may be an issue here (And probably is)
Posted: Tue Jun 27, 2006 11:20 pm
by fordthunderz
ok I'll try that I've been seeing alot about checking the cap for proper venting Thanks
Posted: Thu Jun 29, 2006 2:00 am
by fordthunderz
Yep, pulling a vaccum. Without the cap I get good fuel flow. I replaced the cap so I can only hope that does the trick. I got my chevy fixin tools strapped on, although a six drawer tool box is lookin kinda funny!
Just kiddin!
On the road again!
JR
